Author Topic: [SOLVED] Adding file formats to Gparted  (Read 20695 times)
Offline pooky2483
« on: September 22, 2017, 01:34:33 pm »
How do I add the missing formats to Gparted.
« Last Edit: September 22, 2017, 08:40:05 pm by pooky2483 »
Re: Adding file formats to Gparted
« Reply #1 on: September 22, 2017, 03:26:29 pm »
It tells you in the last column.
So to add btrfs support to Ubuntu:
sudo apt-get install btrfs-tools
but you probably don't want to add this if you're not using btrfs .. it may slow your boot times as it scans for btrfs
Offline pooky2483
« Reply #2 on: September 22, 2017, 05:51:59 pm »
The main one I need is exfat (for micro sd cards) and it has nothing in that column.
« Reply #3 on: September 22, 2017, 06:02:46 pm »
I don't think you can add that to GParted
Though you should be able to read/write to exfat
and the commandline exfat-utils should allow you to do the unticked stuff
Offline pooky2483
« Reply #4 on: September 22, 2017, 08:36:37 pm »
I am unable to read exfat as I have taken the micro SD card out of my mobile as I was having trouble with my laptop having a stable connection.
Offline pooky2483
« Reply #5 on: September 22, 2017, 08:39:38 pm »
I've managed to install exfat.
Earlier today, I had checked Synaptic package manager and it showed that it was installed, I just looked again and it was actually NOT installed.
Re: [SOLVED] Adding file formats to Gparted
« Reply #6 on: September 23, 2017, 02:57:20 am »
Cool 8)
