device, with non-removable media
Model Number: SAMSUNG SSD UM410 Series 2.5" 8GB
Serial Number: DCA0M00940SE940A3673
Firmware Revision: VAM12D1Q
Standards:
Used: ATA/ATAPI-7 T13 1532D revision 1
Supported: 7 6 5 4
Configuration:
Logical max current
cylinders 15525 15525
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 15649200
LBA user addressable sectors: 15649200
LBA48 user addressable sectors: 15649200
Logical/Physical Sector size: 512 bytes
device size with M = 1024*1024: 7641 MBytes
device size with M = 1000*1000: 8012 MBytes (8 GB)
cache/buffer size = unknown
Nominal Media Rotation Rate: Solid State Device
Capabilities:
LBA, IORDY(can be disabled)
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 16 Current = 16
Recommended acoustic management value: 128, current value: 0
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
Security Mode feature set
* Power Management feature set
* Write cache
* Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
SET_MAX security extension
Automatic Acoustic Management feature set
* 48-bit Address feature set
* Device Configuration Overlay feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* WRITE_{DMA|MULTIPLE}_FUA_EXT
* 64-bit World wide name
* WRITE_UNCORRECTABLE_EXT command
* Segmented DOWNLOAD_MICROCODE
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
* Host-initiated interface power management
* Phy event counters
Device-initiated interface power management
* Software settings preservation
Security:
Master password revision code = 65534
supported
not enabled
not locked
frozen
not expired: security count
supported: enhanced erase
6min for SECURITY ERASE UNIT. 6min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 50000f0056414431
NAA : 5
IEEE OUI : 0000f0
Unique ID : 056414431
Checksum: correct
[email protected] ~ $
