Author Topic: Backlight on Acer aspire One d250  (Read 10686 times)
Offline GlenneWenne
« on: September 30, 2017, 01:38:22 pm »
Hi, I have installed Lubuntu 17.04 on my Acer Aspire One D250 (KAV60).
I have also installed a QI Pixel screen on the netbook which makes the screen viewable out in the sun.
I have one problem, though.
When I press fn + f6, the LCD backlight turns off, but whenever I press another key on the keyboard, the backlight turns on again.
This is quite annoying since the QI Pixel screen functions best outdoors when there are no backlight at all.
Is there any way to fix this?
Offline penguin
Re: Backlight on Acer aspire One d250
« Reply #1 on: January 16, 2018, 09:36:31 pm »
Hi- did you find a solution to this problem?
I am tryign to turn off the backlight for pixel QI as well- mine is fitted to a samsung n220. currently using XP but would switch to linux if this could be solved.
Have you tried the things here: https://askubuntu.com/questions/938775/i-cant-turn-off-backlight-after-trying-many-solutions/996757#996757
Maybe they would work on Lubuntu for some reason...?
Offline emegra
« Reply #2 on: January 23, 2018, 07:17:19 pm »
I know little or nothing about this and I'm not on a laptop to test it but it may be possible to use xbacklight
something like xbacklight -set 10 which will drop the backlight level to 10% and if it works you can write a simple script with a a key combo to make the switch
if you want to try it ensure you have xbacklight installed by opening a terminal
sudo apt-get install xbacklight
then to check the current brightness level
xbacklight -get
Then post back the output (if any)
Good luck
