Author Topic: Update showing error - what does it mean? [Solved]  (Read 21463 times)
Offline ahead
  • Full Member
« on: October 09, 2017, 10:03:57 am »
Hello - I tried to install 4 updates in Update Manager today and I got these 2 error messages:
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
E: _cache->open() failed, please report.
What action should I take?
Thank you.
« Last Edit: October 09, 2017, 05:29:21 pm by ahead »
Re: Update showing error - what does it mean?
« Reply #1 on: October 09, 2017, 01:31:00 pm »
Try running:
sudo dpkg --configure -a
and see if you get any errors ?
Offline ahead
  • Full Member
« Reply #2 on: October 09, 2017, 02:23:37 pm »
[sudo] password for graham:
Setting up brscan-skey (0.2.4-1) ...
Setting up brscan4 (0.4.4-3) ...
This software is based in part on the work of the Independent JPEG Group.
This is the result, Mark.
EDIT: Updates have now worked!
« Last Edit: October 09, 2017, 02:28:20 pm by ahead »
« Reply #3 on: October 09, 2017, 02:36:38 pm »
Yep all fixed .. for some reason brscan-skey and brscan4 didn't finish installing/configuring the first time, but they have now :)
Can you please remember to mark the topic (SOLVED) .. TIA :)
You can do this by editing the FIRST posting in this topic and changing:-
Subject: Update showing error - what does it mean? (SOLVED)
« Last Edit: October 09, 2017, 02:41:24 pm by Mark Greaves (PCNetSpec) »
