Author Topic: Install meross AC600 usb wi-fi adaptor.(resolved)  (Read 19103 times)
Offline Tramlink
  • Is the mist clearing
« on: October 12, 2017, 02:53:37 pm »
Running pepermint 8 64bit. this adaptor comes with a CD inclueding drivers for Linux.
Instalation instructions are a little vage.
1.
Using install.sh Script for PC-Linux
For driver compilation and installation in PC-Linux, we provide an install.sh
script to do the duties automatically. If you want to use our Wi-Fi solutions to access
network on PC-Linux, you can just run install.sh script and then control Wi-Fi with
utilities such as Network Manager. For further information about Wi-Fi station mode,
Q. how to run install.sh script?
« Last Edit: January 13, 2018, 05:07:56 pm by Tramlink »
Re: Install meross AC600 usb wi-fi adaptor.
« Reply #1 on: October 12, 2017, 04:10:39 pm »
I take it this is a USB wireless adapter ?
Before we go attempting to install any (possibly unnecessary or wrong) drivers, can you plug in the device and post the output from:
lsusb
sudo lshw -C network
iwlist scan
rfkill list
Offline Tramlink
« Reply #2 on: October 12, 2017, 10:29:32 pm »
[email protected] ~ $ lsusb
Bus 001 Device 003: ID 0bda:a811 Realtek Semiconductor Corp.
Bus 002 Device 002: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
[email protected] ~ $ sudo lshw -C network
[sudo] password for usertwo:
  *-network
       product: AR242x / AR542x Wireless Network Adapter (PCI-Express)
       vendor: Qualcomm Atheros
       physical id: 0
       bus info: [email protected]:02:00.0
       logical name: wlp2s0
       version: 01
       serial: 00:1b:9e:66:a1:b6
       width: 64 bits
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=ath5k driverversion=4.10.0-37-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11
       resources: irq:17 memory:d8100000-d810ffff
  *-network
       product: 88E8039 PCI-E Fast Ethernet Controller
       vendor: Marvell Technology Group Ltd.
       physical id: 0
       bus info: [email protected]:05:00.0
       logical name: enp5s0
       version: 15
       serial: 00:13:77:5c:61:02
       capacity: 100Mbit/s
       width: 64 bits
       capabilities: pm vpd msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 duplex=full ip=192.168.0.10 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:27 memory:d8200000-d8203fff ioport:a000(size=256)
[email protected] ~ $ iwlist scan
wlp2s0    No scan results
enp5s0    Interface doesn't support scanning.
[email protected] ~ $ rfkill list
0: phy0: Wireless LAN
   Soft blocked: no
   Hard blocked: no
« Reply #3 on: October 12, 2017, 11:16:36 pm »
We could attempt to install the drivers that came with it, but I doubt they'll be dkms which means they'll likely break whenever you get a kernel update (if they install at all).
So let's try some dkms packaged drivers first eh ?
(the dkms version of the drivers should recompile automagically when you get kernel updates)
Connect to your router with an ethernet cable and run these commands in sequence:-
sudo apt-get install dkms git
mkdir ~/RTL8812AU
cd ~/RTL8812AU
git clone https://github.com/abperiasamy/rtl8812AU_8821AU_linux.git
cd ~/RTL8812AU/rtl8812AU_8821AU_linux
sudo make -f Makefile.dkms install
then load the driver with:
sudo modprobe rtl8812au
did wireless spring to life ? (you'll need to disconnect from the ethernet cable and set up wireless from the networkmanager system tray icon).
Or REBOOT and see if wireless now works ?
To UNINSTALL
I'm not suggesting you do this yet, I'm just posting the instructions to uninstall this driver "just in case"
sudo make -f Makefile.dkms uninstall
then reboot.
« Last Edit: October 12, 2017, 11:18:10 pm by Mark Greaves (PCNetSpec) »
Offline Tramlink
« Reply #4 on: October 13, 2017, 01:54:04 pm »
OK worked like a dream.......
Many thanks for your help.
« Reply #5 on: October 13, 2017, 02:21:40 pm »
You're most welcome Tramlink :)
Offline Tramlink
« Reply #6 on: October 13, 2017, 02:24:23 pm »
Even working on 5G network.
« Reply #7 on: October 13, 2017, 04:15:03 pm »
Great stuff :)
Any chance you can link to where you got it in case anyone else wants one ?
is this the adapter:
http://www.meross.com/web/products/usb_adapters/2.html
Offline Tramlink
« Reply #8 on: January 10, 2018, 03:56:36 pm »
Yes this is the adaptor I installed.
« Reply #9 on: January 11, 2018, 06:05:56 pm »
Thanks Tramlink :)
Offline Tramlink
Re: Install meross AC600 usb wi-fi adaptor.(Resolved)
« Reply #10 on: January 13, 2018, 11:40:01 am »
1.
« Reply #11 on: January 13, 2018, 03:31:50 pm »
/full/path/to/install.sh
or if it needs elevated privileges:
sudo /full/path/to/install.sh
Offline fishtrousers
Re: Install meross AC600 usb wi-fi adaptor.(resolved)
« Reply #12 on: March 27, 2018, 11:52:05 pm »
Hi, I followed the instructions to install the abperiasamy/rtl8812AU_8821AU_linux.git package but get this error when I try to build:
make[2]: *** /lib/modules/4.4.38-v7+/build: No such file or directory.  Stop.
I've tried installing the headers several times but there's no 'build' directory:
[email protected]/rtl8812AU_8821AU_linux$> ls /lib/modules/4.4.38-v7+/
kernel             modules.builtin      modules.dep.bin  modules.softdep
modules.alias      modules.builtin.bin  modules.devname  modules.symbols
modules.alias.bin  modules.dep          modules.order    modules.symbols.bin
Any suggestions? TIA!
« Reply #13 on: March 28, 2018, 12:02:01 pm »
Is this a RasPi ? .. which distro/version ?
« Reply #14 on: March 28, 2018, 04:41:14 pm »
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.4 LTS
Release:        16.04
Codename:       xenial
