Author Topic: Disability Help  (Read 15143 times)
Offline harry
Disability Help
« on: November 29, 2017, 02:29:58 pm »
We need your help, so all you Linux people out there that may know of or could suggest of any software that would help or assist the Partially  sighted and or Blind persons to use a PC or even add-ons  to the Browsers for Firefox (bearing in mind the update to 57) and Chromium and Google Chrome. We will mainly be using Linux Mint Cinnamon all on 64 bit PC or some laptops. You may be a developer who would like to test some software for our needs well I find someone to test this for you.
But you must remember that it cannot be complicated it's for new users with additional issues just remember the first time you use Linux and how you throw your dummy out out because you couldn’t get it to work.
Offline arochester
Re: Disability Help
« Reply #1 on: November 29, 2017, 07:33:08 pm »
Claus Knopper, who made Knoppix, also made Adriane for his girlfriend who was partially sighted or blind.
http://www.knopper.net/knoppix-adriane/index-en.html
Offline harry
Re: Disability Help
« Reply #2 on: December 02, 2017, 08:44:03 pm »
Wow this is well loaded and it's fast too, I like this OS very much other people should take a look at this but kinder hoping for a little bit easier to use. Bit thanks for your help very much appreciated.
Offline arochester
Re: Disability Help
« Reply #3 on: December 04, 2017, 03:22:20 pm »
Another possibility is Vinux a dedicated distro.
http://wiki.vinuxproject.org/doku.php
Then there are the mainstream distros that might need to be customized.
You might look at https://opensource.com/life/15/8/accessibility-linux-blind-disabled . (Sonar has been discontinued...)
