Author Topic: Installing Chrome  (Read 15388 times)
Offline freelancehelp
Installing Chrome
« on: December 01, 2017, 03:10:46 pm »
I am having problems with Chromium (version 57.0.2987.98 amd64) on
a Jessie desktop system.
Drop down menus on certain websites are not working at all (the menus don't drop down). I understand that Chromium on Jessie is no longer supported.
Rather than going through the whole process of updating from Jessie to Stretch in order to get the latest stable Chromium version (62.0.3202.89),
I was thinking of the possibility of installing the latest version of Chrome on Jessie. I have seen several websites that refer to this process :-
https://askubuntu.com/questions/885973/ ... t-on-16-04
https://www.tecmint.com/install-google- ... linux-mint
My intention would be as follows :-
(1) Click on the following link and download the Google Chrome Browser from Google's website, as appropriate to a Debian 64 bit system :-
https://www.google.co.in/chrome/browser ... index.html
I note that Google's repository will be also be added to my system so that
Chrome can automatically be kept up to date.
(2) Perform an update :-
(3) Install Chrome as follows :-
sudo apt-get install ./google-chrome-stable_current_amd64.deb
(4) Run Chrome :-
$ google-chrome-stable
Would this work okay, with no problems at all ?
Re: Installing Chrome
« Reply #1 on: December 01, 2017, 03:48:10 pm »
Can't see why not (if Debian supports 'sudo') .. give it a try :)
It'd be easy enough to remove if it doesn't work
sudo apt-get remove --purge google-chrome-stable
« Reply #2 on: December 13, 2017, 02:18:41 pm »
 Chrome has now been installed on a Jessie system as follows :-
 (1) Logged into home directory as root.
 (2) Downloaded google-chrome-stable_current_amd64.deb from
      https://www.google.co.in/chrome/browser/desktop/index.html
      to the home directory.
 (3) In the home directory, tried to install Chrome :-
      apt install  ./google-chrome-stable_current_amd64.deb
 (4) This failed, giving lots of error messages such as :-
      E: Release 'google-chrome-stable_current_amd64.deb' for 'firefox-l10n-hr' was not found
 (5) The command :-
       dpkg -i google-chrome-stable_current_amd64.deb
       was then run.
 (6) This gave the messages :-
      Selecting previously unselected package google-chrome-stable.
(Reading database ... 120380 files and directories currently installed.)
Preparing to unpack google-chrome-stable_current_amd64.deb ...
Unpacking google-chrome-stable (63.0.3239.84-1) ...
dpkg: dependency problems prevent configuration of google-chrome-stable:
google-chrome-stable depends on libappindicator1; however:
Package libappindicator1 is not installed.
dpkg: error processing package google-chrome-stable (--install):
dependency problems - leaving unconfigured
Processing triggers for menu (2.1.47) ...
Processing triggers for desktop-file-utils (0.22-1) ...
Processing triggers for mime-support (3.58) ...
Processing triggers for man-db (2.7.0.2-5) ...
 (7) So the command :-
      apt-get -f install
      and then the command :-
      were run.
 (8) Then the command :-
     was run to start Chrome.
 (9) This produced the following error messages :-
     libGL error: failed to open drm device: Permission denied
libGL error: failed to load driver: nouveau
ATTENTION: default value of option force_s3tc_enable overridden by environment.
[32145:32145:1211/192714.812289:ERROR:sandbox_linux.cc(351)] InitializeSandbox() called with multiple threads in process gpu-process.
     Can anyone please explain what these errors mean and how can they be resolved ?
     Chrome runs to some extent but I would like to clear up the above errors.
      Thanks very much.
« Reply #3 on: May 23, 2019, 12:05:36 pm »
Chrome has problems with producing dropdown menus.
 Has anyone else come across this problem ?
 Would the latest version of Chrome solve this problem ?
« Reply #4 on: May 23, 2019, 02:18:06 pm »
I'm personally not seeing any problems with Chrome or Chromium (but then I'm on an Ubuntu base) .. but it's always a good idea to have the latest version of a web browser.
