Author Topic: Sound issue in Game Fantastic Farm revised for mint 18.2 (Resolved)  (Read 4746 times)
Offline Tramlink
  • Is the mist clearing
I am using mint 18.2 64bit Cinereum
And yet again with a change to a newer version my wife's favourite game has lost its sound.
Below is a link to how it was solved for mint 17.3 64bit mate.
https://linuxforums.org.uk/index.php?topic=11010.msg95864#msg95864
I tried using the mint 17.3 fix but not working.
Any assistance welcome.
« Last Edit: January 18, 2018, 12:55:36 pm by Tramlink »
Re: Sound issue in Game Fantastic Farm revised for mint 18.2
« Reply #1 on: January 18, 2018, 12:07:36 pm »
As in that link you said it was the "second" command that worked, run:
sudo updatedb
locate libpulsedsp.so
and if:-
/usr/lib/i386-linux-gnu/pulseaudio/libpulsedsp.so
isn't listed in the output, you'll need to install the 32bit version of libpulsedsp with:
sudo apt-get install libpulsedsp:i386
then try running:
bash -c "LD_PRELOAD=/usr/lib/i386-linux-gnu/pulseaudio/libpulsedsp.so /home/userone/fantasticfarm/'Fantastic Farm'"
and see if it works ?
If not, what was the output from that command ?
Offline Tramlink
« Reply #2 on: January 18, 2018, 12:55:13 pm »
installing libpulsedsp:i386 32bit version did the trick so working fine now.
Thanks for the hint.
Re: Sound issue in Game Fantastic Farm revised for mint 18.2 (Resolved)
« Reply #3 on: January 18, 2018, 01:25:32 pm »
Glad I could help Tramlink :)
