Author Topic: Meltdown/Spectre patches(Solved)  (Read 9325 times)
Offline Degsy
  • Sr. Member
« on: January 20, 2018, 02:53:18 pm »
You recently posted on the peppermint forum a link for users of Pep 6 to update for the above, this I have done, thanks, however just wondering about Ubuntu 14.04 which I run dual booted with Pep 6, how can i ensure that I have the latest patches for the problems with Meltdown/Spectre.
Thanks in advance for your help.
Regards,
Degsy.
« Last Edit: January 22, 2018, 08:13:25 pm by Degsy »
Re: Meltdown/Spectre patches
« Reply #1 on: January 20, 2018, 03:40:07 pm »
I doubt you need to do anything in Ubuntu 14.04 (besides normal updates) as long as you're on their default kernel.
But if you wish, the same HWE update **could** be applied to Ubuntu 14.04 .. just update to the HWE (as per the instructions either in the Peppermint posting or) here:
https://wiki.ubuntu.com/Kernel/LTSEnablementStack
If you want to be sure, post the output from:
uname -a
from within Ubuntu 14.04
« Last Edit: January 20, 2018, 03:45:21 pm by Mark Greaves (PCNetSpec) »
Offline Degsy
  • Sr. Member
« Reply #2 on: January 20, 2018, 06:35:58 pm »
Ran the suggestion as per the website you mentioned, this is the result of the Terminal command.
derek@derek-MM061:~$ uname -a
Linux derek-MM061 3.13.0-137-generic #186-Ubuntu SMP Mon Dec 4 19:09:19 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Regards,
Degsy
« Reply #3 on: January 20, 2018, 08:54:33 pm »
Either the HWE update didn't work, or you haven't rebooted yet to boot the HWE kernel because your currently booted kernel is NOT a patched version.
The standard 14.04 kernel was patched at version 3.13.0-139 (or higher)
and 14.04 with the HWE should be running the patched 4.4.0-109 kernel (or higher)
Reboot, then post the output from:
uname -a
again ?
« Last Edit: January 20, 2018, 09:01:13 pm by Mark Greaves (PCNetSpec) »
Offline Degsy
  • Sr. Member
« Reply #4 on: January 20, 2018, 09:46:24 pm »
Rebooted, got same response to uname -a.
Repeated sudo apt-get update, got the following error at the end:
W: Failed to fetch http://ppa.launchpad.net/lestcape/cinnamon/ubuntu/dists/trusty/main/binary-amd64/Packages  403  Forbidden
W: Failed to fetch http://ppa.launchpad.net/lestcape/cinnamon/ubuntu/dists/trusty/main/binary-i386/Packages  403  Forbidden
E: Some index files failed to download. They have been ignored, or old ones used instead.
Advice please
Degsy
« Reply #5 on: January 20, 2018, 09:54:00 pm »
Okay can you explain:-
and post the output from:
ls /etc/apt/sources.list.d
And have you attempted to install Cinnamon in Ubuntu 14.04 at some point ? .. is it still installed ?
« Last Edit: January 20, 2018, 09:58:27 pm by Mark Greaves (PCNetSpec) »
Offline Degsy
  • Sr. Member
« Reply #6 on: January 20, 2018, 10:09:11 pm »
Hi,
derek@derek-MM061:~$ ls /etc/apt/sources.list.d
lestcape-cinnamon-trusty.list       teejee2008-ppa-trusty.list
lestcape-cinnamon-trusty.list.save  teejee2008-ppa-trusty.list.save
Initially I ran sudo apt-get update, then sudo apt-get dist-upgrade, then rebooted.
I then copied and pasted the lengthy command into the Terminal and proceeded, it seemed to be going ok as the 4.4.0-109 number appeared several times during the process, however after reboot and uname -a the result was as previously given.
I have not knowingly attempted to install cinnamon.
Degsy
« Reply #7 on: January 20, 2018, 10:14:07 pm »
Okay run these commands in sequence:
cd /etc/apt/sources.list.d
sudo rm -v lestcape-cinnamon-trusty.list
sudo rm -v lestcape-cinnamon-trusty.list.save
if that command finishes without error, REBOOT
Then post the output from:
uname -a
Offline Degsy
  • Sr. Member
« Reply #8 on: January 20, 2018, 10:26:34 pm »
Ran the commands as requested, no errors given,
Degsy
« Reply #9 on: January 20, 2018, 11:11:44 pm »
Okay try running:
sudo apt-get install --install-recommends dkms linux-generic-lts-xenial xserver-xorg-core-lts-xenial xserver-xorg-lts-xenial xserver-xorg-video-all-lts-xenial xserver-xorg-input-all-lts-xenial libwayland-egl1-mesa-lts-xenial libgl1-mesa-glx-lts-xenial libgl1-mesa-glx-lts-xenial:i386 libglapi-mesa-lts-xenial:i386 libudev1:i386 libcgmanager0:i386
again.
Then reboot
uname -a
again.
Offline Degsy
  • Sr. Member
« Reply #10 on: January 20, 2018, 11:22:39 pm »
hi,
Degsy
« Reply #11 on: January 21, 2018, 12:43:29 am »
okay what's the output from:
dpkg -l | grep linux-image
Offline Degsy
  • Sr. Member
« Reply #12 on: January 21, 2018, 11:13:41 am »
Good morning Mark,
As requested:
derek@derek-MM061:~$ dpkg -l | grep linux-image
ii  linux-image-3.13.0-100-generic                        3.13.0-100.147                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-101-generic                        3.13.0-101.148                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-106-generic                        3.13.0-106.153                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-109-generic                        3.13.0-109.156                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-112-generic                        3.13.0-112.159                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-116-generic                        3.13.0-116.163                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-119-generic                        3.13.0-119.166                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-125-generic                        3.13.0-125.174                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-126-generic                        3.13.0-126.175                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-133-generic                        3.13.0-133.182                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-135-generic                        3.13.0-135.184                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-137-generic                        3.13.0-137.186                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-139-generic                        3.13.0-139.188                                      amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-24-generic                         3.13.0-24.47                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-30-generic                         3.13.0-30.55                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-32-generic                         3.13.0-32.57                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-33-generic                         3.13.0-33.58                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-34-generic                         3.13.0-34.60                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-35-generic                         3.13.0-35.62                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-36-generic                         3.13.0-36.63                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-37-generic                         3.13.0-37.64                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-39-generic                         3.13.0-39.66                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-40-generic                         3.13.0-40.69                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
rc  linux-image-3.13.0-53-generic                         3.13.0-53.89                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-54-generic                         3.13.0-54.91                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-55-generic                         3.13.0-55.94                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-57-generic                         3.13.0-57.95                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-63-generic                         3.13.0-63.103                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-68-generic                         3.13.0-68.111                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-71-generic                         3.13.0-71.114                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-73-generic                         3.13.0-73.116                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-74-generic                         3.13.0-74.118                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-76-generic                         3.13.0-76.120                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-77-generic                         3.13.0-77.121                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-79-generic                         3.13.0-79.123                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-83-generic                         3.13.0-83.127                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-85-generic                         3.13.0-85.129                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-86-generic                         3.13.0-86.131                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-88-generic                         3.13.0-88.135                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-91-generic                         3.13.0-91.138                                       amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-109-generic                         4.4.0-109.132~14.04.1                               amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-100-generic                  3.13.0-100.147                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-101-generic                  3.13.0-101.148                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-106-generic                  3.13.0-106.153                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-109-generic                  3.13.0-109.156                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-112-generic                  3.13.0-112.159                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-116-generic                  3.13.0-116.163                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-119-generic                  3.13.0-119.166                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-125-generic                  3.13.0-125.174                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-126-generic                  3.13.0-126.175                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-133-generic                  3.13.0-133.182                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-135-generic                  3.13.0-135.184                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-137-generic                  3.13.0-137.186                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-139-generic                  3.13.0-139.188                                      amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-24-generic                   3.13.0-24.47                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-30-generic                   3.13.0-30.55                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-32-generic                   3.13.0-32.57                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-33-generic                   3.13.0-33.58                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-34-generic                   3.13.0-34.60                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-35-generic                   3.13.0-35.62                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-36-generic                   3.13.0-36.63                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-37-generic                   3.13.0-37.64                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-39-generic                   3.13.0-39.66                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-40-generic                   3.13.0-40.69                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
rc  linux-image-extra-3.13.0-53-generic                   3.13.0-53.89                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-54-generic                   3.13.0-54.91                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-55-generic                   3.13.0-55.94                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-57-generic                   3.13.0-57.95                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-63-generic                   3.13.0-63.103                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-68-generic                   3.13.0-68.111                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-71-generic                   3.13.0-71.114                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-73-generic                   3.13.0-73.116                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-74-generic                   3.13.0-74.118                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-76-generic                   3.13.0-76.120                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-77-generic                   3.13.0-77.121                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-79-generic                   3.13.0-79.123                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-83-generic                   3.13.0-83.127                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-85-generic                   3.13.0-85.129                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-86-generic                   3.13.0-86.131                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-88-generic                   3.13.0-88.135                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-91-generic                   3.13.0-91.138                                       amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-109-generic                   4.4.0-109.132~14.04.1                               amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-generic                                   3.13.0.139.148                                      amd64        Generic Linux kernel image
ii  linux-image-generic-lts-xenial                        4.4.0.109.92                                        amd64        Generic Linux kernel image
« Reply #13 on: January 21, 2018, 06:31:46 pm »
Good god you have a LOT of old kernels installed.
First try running:
sudo update-grub
then reboot
uname -a
« Last Edit: January 21, 2018, 06:34:30 pm by Mark Greaves (PCNetSpec) »
« Reply #14 on: January 21, 2018, 06:35:00 pm »
Hold on .. did you say this was a dual boot setup with 2 Linux distros ?
If so, run:
sudo update-grub
in BOTH distros.
Then boot into 14.04 and post the output from:
uname -a
