Author Topic: Meltdown and Spectre (SOLVED)  (Read 5830 times)
Re: Meltdown and Spectre
« Reply #15 on: January 28, 2018, 06:10:00 pm »
Okay WITH ONLY THE 18.3 DRIVE ATTACHED, boot to the 18.3 LiveUSB/LiveDVD and run these commands in sequence:
sudo mount /dev/sda5 /mnt
sudo mount /dev/sda1 /mnt/boot
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
sudo chroot /mnt
grub-install /dev/sda
update-grub
then hit Ctrl+D to exit the chroot environment
And reboot without the LiveUSB/LiveDVD
Did it boot ?
Offline Rich J
  • Sr. Member
  • A Linux Luvvie!
« Reply #16 on: January 29, 2018, 05:06:33 pm »
sudo chroot /mnt
update-grub
Did it boot ?
Sadly no.  Did as asked - Updated Grub sees both installed kernels (4.13.xx and 4.10.xx) but neither will boot.
« Reply #17 on: January 29, 2018, 08:39:49 pm »
Are you still seeing this message:-
not syncing: VFS unable to mount root fs on unknown-block (0,0)
Offline Rich J
  • Sr. Member
  • A Linux Luvvie!
« Reply #18 on: January 29, 2018, 10:01:55 pm »
Yes, exactly the same.
EDIT:  This message repeats about 4 times or so down the page, as if it is in a loop almost and is trying to re-boot?
« Last Edit: January 29, 2018, 10:04:53 pm by Rich J »
« Reply #19 on: January 30, 2018, 12:19:47 am »
sudo chroot /mnt
update-initramfs -uk all
If you get any errors, write them down and let me know .. otherwise...
hit Ctrl+D to exit the chroot environment.
Reboot to test.
Offline Rich J
  • Sr. Member
  • A Linux Luvvie!
« Reply #20 on: January 30, 2018, 10:51:41 am »
Hi Mark!
Thank you so much!  That last set sorted the issue so I'll mark it as solved.  (The only 'error' reported was "No support for locale: en_GB.utf8, which appears all the time whichever Mint distro you're updating).
I have noticed one anomaly though, in GParted.  The first partition  (/dev/sda1- boot) lies outside of the second partition (/dev/sda2 - extended)  Should it?  Or should all partitions reside within the extended partition?  I'm wondering if this might be causing the issues I've had?
I can try for a screen shot if you can tell me where to post it?
Thanks again
Rich
« Reply #21 on: January 30, 2018, 03:01:55 pm »
In Linux it doesn't matter if the /boot partition is in an extended partition (or not), GRUB will be able to boot from it anyway .. Windows on the other hand MUST have it's bootloader in a primary partition.
Offline Rich J
  • Sr. Member
  • A Linux Luvvie!
« Reply #22 on: January 30, 2018, 03:30:21 pm »
Understood, thanks.  ;)
All seems ok with M18.3 booting and both user accounts are able to log in.  Kernel in use is  -
richard@richard-OEM ~ $ uname -a
Linux richard-OEM 4.13.0-32-generic #35~16.04.1-Ubuntu SMP Thu Jan 25 10:13:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
I've reconnected my 2nd Hdd but Grub now doesn't see it since the update.  I assume I 'sudo update-grub' from M18.3 to enable it?
« Last Edit: January 30, 2018, 03:34:23 pm by Rich J »
« Reply #23 on: January 30, 2018, 05:16:48 pm »
Yeah run
sudo update-grub
from within 18.3 (if it's the primary boot device)
Offline Rich J
  • Sr. Member
  • A Linux Luvvie!
« Reply #24 on: January 30, 2018, 07:55:57 pm »
Yeah run
sudo update-grub
Ok - all done and dusted!  Thanks again!
Re: Meltdown and Spectre (SOLVED)
« Reply #25 on: February 01, 2018, 01:39:19 am »
No problem Rich :)
