Author Topic: Firefox crashing after update. [Solved]  (Read 5395 times)
Offline ahead
  • Full Member
« on: January 25, 2018, 10:55:53 am »
I have Mint 17.3 Rosa 64bit and did a recommended update on Firefox yesterday,  since then Firefox keeps crashing with the following idiotic message: 'Gah. your tab has just crashed'. It then invites me to report this to them etc. Can you advise me how to fix this - preferably reverse the update so that Firefox can work properly again?
« Last Edit: February 21, 2018, 09:51:00 am by ahead »
Re: Firefox crashing after update.
« Reply #1 on: January 25, 2018, 11:47:37 pm »
Well you can revert back to FF57 but from what Mozilla say here:
https://www.mozilla.org/en-US/firefox/58.0/releasenotes/
Quote from: Firefox 58 Release Notes
User profiles created in Firefox 58 (and in future releases) are not supported in previous versions of Firefox. Users who downgrade to a previous version should create a new profile for that version
So if you want to go back to FF57 you're going to have to delete/rename your Firefox profile, loosing all your bookmarks, etc. unless you have them synced .. are you okay with that ?
If so, it might be a good idea to just rename the profile but stick with FF58 first, just to check if it was something in your profile that's messing things up.
Let me know what you want to do, and we'll go from there.
also post the output from:
uname -a
Offline ahead
  • Full Member
« Reply #2 on: January 26, 2018, 09:02:54 am »
Hmm...Thanks Brian, I suppose I'll stay with the new 'improved' version!
If you can help sort it out I would be very grateful. Here is the output you requested:
 uname -a
Linux graham-HP-ProBook-455-G2 3.19.0-32-generic #37~14.04.1-Ubuntu SMP Thu Oct 22 09:41:40 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Thanks again.
« Last Edit: January 26, 2018, 09:07:11 am by ahead »
« Reply #3 on: January 26, 2018, 01:52:20 pm »
Okay try this...
WITH ALL INSTANCES OF FIREFOX CLOSED, run:
mv -v ~/.mozilla ~/.mozilla-old
Now sttart Firefox and see how it behaves .. and let us know.
Offline ahead
  • Full Member
« Reply #4 on: January 27, 2018, 05:25:26 pm »
It seems a bit more stable but unfortunately it is still occasionally crashing.
« Reply #5 on: January 27, 2018, 08:26:59 pm »
Maybe you'd like to try the FF59 beta ?
If so, what's the output from:
dpkg -l | grep firefox
Offline ahead
  • Full Member
« Reply #6 on: January 29, 2018, 08:33:02 am »
Mark, it seems to have settled a bit, I'll see how things go over the next couple of days or so and then conclude this one way or another.
« Reply #7 on: January 29, 2018, 01:03:14 pm »
Okay let me know, and we'll go from there.
Offline ahead
  • Full Member
« Reply #8 on: February 08, 2018, 12:13:29 pm »
No, it's still playing up, crashing and randomly refusing to play some videos so I will have a go at FF59 as you suggest, please.
graham@graham-HP-ProBook-455-G2 ~ $ dpkg -l | grep firefox
ii  firefox                                     58.0.1+linuxmint1+rosa                              amd64        Safe and easy web browser from Mozilla
ii  firefox-locale-en                           58.0.1+linuxmint1+rosa                              amd64        English language pack for Firefox
Many thanks.
« Reply #9 on: February 08, 2018, 05:16:11 pm »
To change to Firefox version 59.0~b7 run these commands in sequence:
mkdir ~/Desktop/FF59beta-installation-files
cd ~/Desktop/FF59beta-installation-files
wget https://launchpad.net/~mozillateam/+archive/ubuntu/firefox-next/+files/firefox_59.0~b7+build1-0ubuntu0.16.04.1_amd64.deb
wget https://launchpad.net/~mozillateam/+archive/ubuntu/firefox-next/+files/firefox-locale-en_59.0~b7+build1-0ubuntu0.16.04.1_amd64.deb
sudo apt-get install ./firefox_59.0~b7+build1-0ubuntu0.16.04.1_amd64.deb ./firefox-locale-en_59.0~b7+build1-0ubuntu0.16.04.1_amd64.deb
then close ALL running instances of Firefox .. then repoen one.
TO UNDO (ie. return to the default 58.0.1 version of Firefox):
sudo apt-get install firefox=58.0.1+linuxmint1+rosa firefox-locale-en=58.0.1+linuxmint1+rosa
« Last Edit: February 08, 2018, 05:18:54 pm by Mark Greaves (PCNetSpec) »
Offline ahead
  • Full Member
« Reply #10 on: February 09, 2018, 08:04:32 am »
Thanks Mark, I shall have a go at that.
Done that, unfortunately no change. However, a folder entitled FF59 Beta-Installation-Files has appeared on the desktop, inside are 2 folders:
 /home/graham/Desktop/FF59beta-installation-files/firefox_59.0~b7+build1-0ubuntu0.16.04.1_amd64.deb
AND:
/home/graham/Desktop/FF59beta-installation-files/firefox-locale-en_59.0~b7+build1-0ubuntu0.16.04.1_amd64.deb
When I try to install the 1st one I get a long error message in red 'Breaks existing package Hunspell-en-us that conflict Iceweasel...goes on to say that the installation files provides it via gnome-www-browser,iceweasel, www-browser. Nothing more is then clickable.
On attempting to open 2nd folder I am warned about dangers of downloading from unknown sources.
« Last Edit: February 10, 2018, 09:00:47 am by ahead »
« Reply #11 on: February 10, 2018, 12:10:22 pm »
What's the output from:
now ?
Offline ahead
  • Full Member
« Reply #12 on: February 10, 2018, 02:42:05 pm »
I've re-installed and it seems better now, however, here is the output you requested:
ii  firefox-locale-en                           59.0~b7+build1-0ubuntu0.16.04.1                     amd64        English language pack for Firefox
« Reply #13 on: February 10, 2018, 06:20:33 pm »
You still have firefox 58 installed.
As long as you didn't delete that desktop folder, run:
sudo apt-get install /home/$USER/Desktop/FF59beta-installation-files/firefox_59.0~b7+build1-0ubuntu0.16.04.1_amd64.deb
or if that doesn't work
dpkg -i firefox_59.0~b7+build1-0ubuntu0.16.04.1_amd64.deb
then close ALL running instances of Firefox and reopen
Offline Thomas_Raymond
« Reply #14 on: February 12, 2018, 07:53:15 am »
I was also facing the same issue about crashing after update. Then finally I uninstalled it, download it and reinstall again now I'm using the latest version of Firefox without any issue.
