Author Topic: Firefox crashing after update. [Solved]  (Read 5175 times)
Offline ahead
  • Full Member
Re: Firefox crashing after update.
« Reply #15 on: February 12, 2018, 08:33:15 am »
None of the actions have worked unfortunately.
« Reply #16 on: February 12, 2018, 05:58:03 pm »
Maybe you should try Waterfox .. that's based on the pre-quantum Firefox
To installl
echo 'deb https://dl.bintray.com/hawkeye116477/waterfox-deb release main' | sudo tee /etc/apt/sources.list.d/waterfox.list
curl https://bintray.com/user/downloadSubjectPublicKey?username=hawkeye116477 | sudo apt-key add -
sudo apt-get install waterfox
Offline ahead
  • Full Member
« Reply #17 on: February 13, 2018, 09:08:14 am »
@Thomas_Raymond: Thanks, I have installed Chrome and tried Opera as FF updates did't cure the problem.
Seen some interesting +ve reviews of Waterfox, Mark so I shall give it a go.
Offline ahead
  • Full Member
Re: Firefox crashing after update. [Solved]
« Reply #18 on: February 21, 2018, 09:53:56 am »
Have used Waterfox for a fortnight now - very good, just like having my original FF back, thanks again Mark.
« Reply #19 on: February 21, 2018, 03:07:40 pm »
NP :)
