Author Topic: dual booting peppermint 8 Linux with windows10 on an Acer ES15 (SOLVED)  (Read 7577 times)
Re: dual booting peppermint 8 with windows10
« Reply #15 on: March 06, 2018, 03:38:47 pm »
Boot to the Peppermint LiveUSB, open a terminal and run:
sudo efibootmgr -o 2001,0001,0000,2002,2003
Now REBOOT but be ready to hit F12 to enter the boot device selection screen.
Is "ubuntu" listed now ?
If so, what happens if you select it ?
Offline normanliddle
« Reply #16 on: March 08, 2018, 07:24:50 pm »
Thanks for your reply Mark, ran your commands in the terminal, after hitting Enter the response was: Boot entry 0000 does not exist? Ran with it any way
but still booting straight to WINDOWS with no mention of Ubuntu?  Any help is appreciated. Yours Norman
« Reply #17 on: March 08, 2018, 08:09:34 pm »
Okay, do you know how to boot the Peppermint LiveUSB in UEFI mode ?
« Reply #18 on: March 09, 2018, 03:50:25 pm »
No Mark I don't. But I'm open to any advice from you. Yours norman.
« Reply #19 on: March 09, 2018, 04:00:42 pm »
Okay, when you boot the Peppermint 8 64bit LiveUSB, do you see the GRUB  menu .. or do you see this:
« Reply #20 on: March 09, 2018, 05:04:51 pm »
Hi Mark I get this when i boot into the USB.
GNU GRUB version 2.02 beta 2.36 version u3
Try Peppermint without installing
Install Peppermint
OEM install for manufactures
Thanks for replying( the laptop started talking assumed it was you? I could not understand I am very hard of hearing from an accident long time ago
in the Royal Navy.
« Reply #21 on: March 09, 2018, 09:17:19 pm »
Not sure what you mean by "the laptop started talking" .. but it certainly wasn't me.
Anyway we can have a go at reinstalling the Peppermint bootloader...
Boot to the Peppermint 8 64bit LiveUSB .. from the GRUB screen choose "Try Peppermint" .. when you end up at the desktop, open a terminal by hitting Ctrl+Alt+T .. then run the following commands in sequence:
sudo mount /dev/sda5 /mnt
then:
sudo mount /dev/sda1 /mnt/boot/efi
then:
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
then:
sudo chroot /mnt
then:
grub-install /dev/sda
then:
update-grub
Now hit Ctrl+D to exit the chroot environment.
Now reboot to test.
« Reply #22 on: March 11, 2018, 06:16:55 pm »
Hi Mark, I followed your instructions to the letter but on reboot I still end up in Windows. The terminal reported everything as correct after each command?
I think its me taking the flash drive out at the wrong time when commencing the reboot? I'm rebooting from the whisper menu logout screen, after typing exit into the terminal prompt.
« Reply #23 on: March 11, 2018, 07:06:05 pm »
Is Ubuntu now listed in the UEFI boot selection screen ?
Is there anything in the BIOS about locking the EFI partition ?
« Reply #24 on: March 12, 2018, 03:23:28 pm »
Thanks for replying so quickly Mark. I accessed the Uefi firmware settings and copied this:(cannot find Ubuntu or see anything locking EFI. F12 Boot is disabled in another window?)
Insyde H20 Setup Utilities
Boot Mode               UEFI
Secure Boot             Enabled
 Boot        5. USB HDD
1. USB FDD                                                        6. USB CDROM
2. HDD: ST1000LM02 HN-M101MBB                     7. Network Boot-IPV6
3. ATAPI CDROM Slimtype DVD A DA89ESH           8. Windows Boot Manager
4. Network Boot-IPV4
5. USB HDD
« Reply #25 on: March 18, 2018, 12:24:15 am »
Apology's Mark, 5. USB HDD twice is a typing error by me. It,s only listed once in the EUFI/BIOS window. re: the previous post.
Yours norman liddle.
« Reply #26 on: March 18, 2018, 01:03:36 pm »
Are you interested in deleting the Linux partitions, and the Linux EFI entry, and attempting another install ?
Let me know and I'll post instructions.
« Reply #27 on: March 18, 2018, 11:50:13 pm »
I'm sure this is the best way to go.Thanks for your time regarding this problem. Your's norman liddle.
« Reply #28 on: March 19, 2018, 12:35:33 pm »
Okay, can you boot to the LiveUSB and run:
sudo mkdir /mnt/efi
sudo mount /dev/sda1 /mnt/efi
then post the output from
sudo ls /mnt/efi/EFI
« Reply #29 on: March 19, 2018, 05:02:05 pm »
peppermint@peppermint ~ $ sudo mkdir /mnt/efi
peppermint@peppermint ~ $ sudo mount /dev/sda1 /mnt/efi
peppermint@peppermint ~ $ sudo ls /mnt/efi/EFI
Boot  Microsoft  OEM  ubuntu
Mark is this OK. I still cannot get my head around booting into the trial version of peppermint 8 then posting this. Yours, Norman Liddle
