Author Topic: dual booting peppermint 8 Linux with windows10 on an Acer ES15 (SOLVED)  (Read 9230 times)
Re: dual booting peppermint 8 with windows10
« Reply #30 on: March 19, 2018, 06:46:38 pm »
Can you boot to the LiveUSB and post the output from
efibootmgr -v
again.
Offline normanliddle
« Reply #31 on: March 20, 2018, 06:59:16 pm »
peppermint@peppermint ~ $ efibootmgr -v
BootCurrent: 0002
Timeout: 0 seconds
BootOrder: 2001,0001,2002,2003
Boot0000* ubuntu   HD(1,GPT,b59d2b94-1a6a-466a-968f-dfe8b4f0022b,0x800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0001* Windows Boot Manager   HD(1,GPT,b59d2b94-1a6a-466a-968f-dfe8b4f0022b,0x800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}....................
Boot0002* USB HDD: SanDisk Cruzer Micro   PciRoot(0x0)/Pci(0x1d,0x0)/USB(0,0)/USB(3,0)/HD(1,MBR,0x14,0x800,0x77f27f)RC
Boot0003* Unknown Device:    HD(1,GPT,b59d2b94-1a6a-466a-968f-dfe8b4f0022b,0x800,0x32000)/File(\EFI\ubuntu\shimx64.efi)RC
Boot0005* Unknown Device:    HD(1,GPT,b59d2b94-1a6a-466a-968f-dfe8b4f0022b,0x800,0x32000)/File(\EFI\ubuntu\shimx64.efi)RC
Boot0009* Unknown Device:    HD(1,GPT,b59d2b94-1a6a-466a-968f-dfe8b4f0022b,0x800,0x32000)/File(\EFI\ubuntu\shimx64.efi)RC
Boot2001* EFI USB Device   RC
Boot2002* EFI DVD/CDROM   RC
Boot2003* EFI Network   RC
Thanks Mark hope this is what you want. Yours Norman.
« Reply #32 on: March 21, 2018, 04:34:17 pm »
Okay, boot to the LiveUSB and run:
sudo efibootmgr -Bb 0000
sudo mkdir /mnt/efi
sudo mount /dev/sda1 /mnt/efi
then:
sudo rm -rvf /mnt/efi/EFI/ubuntu
now post the output from:
sudo ls /mnt/efi/EFI
sudo efibootmgr -v
then confirm you can still reboot to Windows.
« Reply #33 on: March 21, 2018, 07:00:56 pm »
peppermint@peppermint ~ $ sudo efibootmgr -Bb 0000
efibootmgr: Could not delete Boot0000: No such file or directory
efibootmgr: Could not delete boot variable: No such file or directory
peppermint@peppermint ~ $ sudo mkdir /mnt/efi
peppermint@peppermint ~ $ sudo mount /dev/sda1 /mnt/efi
peppermint@peppermint ~ $ sudo rm -rvf /mnt/efi/EFI/ubuntu
removed directory '/mnt/efi/EFI/ubuntu/fw'
removed '/mnt/efi/EFI/ubuntu/fwupx64.efi'
removed '/mnt/efi/EFI/ubuntu/grubx64.efi'
removed '/mnt/efi/EFI/ubuntu/grub.cfg'
removed '/mnt/efi/EFI/ubuntu/shimx64.efi'
removed '/mnt/efi/EFI/ubuntu/mmx64.efi'
removed directory '/mnt/efi/EFI/ubuntu'
peppermint@peppermint ~ $ sudo ls /mnt/efi/EFI
Boot  Microsoft  OEM
peppermint@peppermint ~ $ sudo efibootmgr -v
BootCurrent: 0002
Timeout: 0 seconds
Mark,I made a mistake the first attempt at this , the terminal did report after the fist command but I lost it re 0000? Yours, Norman
« Reply #34 on: March 21, 2018, 07:08:25 pm »
Hi Mark, removed the usb drive and booted into windows OK. Yours sincerely, Norman.
« Reply #35 on: March 21, 2018, 07:39:57 pm »
reboot to the LiveUSB and run:
sudo efibootmgr -Bb 0003
sudo efibootmgr -Bb 0005
sudo efibootmgr -Bb 0009
then post the output from:
sudo efibootmgr -v
« Reply #36 on: March 22, 2018, 11:20:51 am »
peppermint@peppermint ~ $ sudo efibootmgr -Bb  003
BootCurrent: 0002
Timeout: 0 seconds
peppermint@peppermint ~ $ sudo efibootmgr -Bb 0005
BootCurrent: 0002
Timeout: 0 seconds
peppermint@peppermint ~ $ sudo -Bb 0009
sudo: invalid option -- 'B'
usage: sudo -h | -K | -k | -V
usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command]
usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-g group] [-h host] [-p prompt]
            [-u user] [VAR=value] [-i|-s] [<command>]
usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-g group] [-h host] [-p prompt]
            [-u user] file ...
BootCurrent: 0002
Timeout: 0 seconds
Boot0002* USB HDD: SanDisk Cruzer Micro   PciRoot(0x0)/Pci(0x1d,0x0)/USB(0,0)/USB(3,0)/HD(1,MBR,0x14,0x800,0x77f27f)RCT
Thanks Mark,Norman.
« Reply #37 on: March 25, 2018, 12:44:14 pm »
sudo efibootmgr -v
sudo fdisk -l
sudo blkid
also run:
sudo mkdir /mnt/efi
cd /mnt/efi/EFI
sudo rm -rvf ubuntu
« Last Edit: March 25, 2018, 12:53:30 pm by Mark Greaves (PCNetSpec) »
« Reply #38 on: March 25, 2018, 08:42:41 pm »
peppermint@peppermint ~ $ sudo efibootmgr -Bb 0009
BootCurrent: 0002
Timeout: 0 seconds
BootCurrent: 0002
Timeout: 0 seconds
peppermint@peppermint ~ $ peppermint@peppermint ~ $ sudo mkdir /mnt/efi
peppermint@peppermint ~ $ cd /mnt/efi/EFI
peppermint@peppermint /mnt/efi/EFI $ sudo rm -rvf ubuntu
peppermint@peppermint /mnt/efi/EFI $ sudo ls /mnt/efi/EFI
Boot  Microsoft  OEM
Thanks again Mark for your time. Norman
« Reply #39 on: March 26, 2018, 01:11:25 pm »
Okay, boot to the LiveUSB and fire up:-
Menu > System Tools > GParted
In the main pane, right-click on the /dev/sda6 partition and select "Swapoff"
Now right-click the /dev/sda6 partition again and select "Delete"
Now right-click on the /dev/sda5 partition and select "Delete"
When you're 100% sure you've marked ONLY the /dev/sda5 and /dev/sda6 partitions for deletion click the "Apply" button.
Once GParted finishes applying those changes, close Gparted.
With Gparted closed, double-click the "Install Peppermint" icon on the desktop .. and work your way through the installation, allowing Peppermint to be installed in the free space.
« Reply #40 on: March 26, 2018, 08:34:18 pm »
Hello Mark, I followed your instructions to the letter and everything appeared to pan out. Installed pep 8 alongside windows boot manager in the installation
and followed the manager with no problems at all? But on rebooting after installation and removing the usb drive it booted straight to WINDOWS? checked the bios and windows boot manager is the last item in the list at no.8. But I have no option to boot onto peppermint 8 anywhere. I must be doing something wrong but cannot figure it out? Yours sincerely Norman. WHEN I BOOTUP THE SYSTEM HAS BEEN GOING TO A CHOICE OF WINDOWS 10 OR MACRIUM REFLECT, this has been the boot sequence since I started trying to install peppermint 8 do you think this may be the problem? Have tried all the options in these windows but no sign of Ubuntu?. yours Norman.
« Reply #41 on: March 26, 2018, 11:34:41 pm »
What's the make and model of this PC ?
« Reply #42 on: March 27, 2018, 08:55:24 pm »
hi Mark, thanks for your reply, the laptop is an Acer. manufactured date 30.08.2016,model is Aspire ES1.571.P1VN. i am away this week on Thursday
with the motor home camping wild with no electric or internet connection so cannot contact you. Is it ok to get in touch with you after Easter back next Wednesday? I think I caused the laptop to boot this way Windows boot loader was first in the bios and I put it last to boot from the usb first. The laptop
booted ok after this but once over I think I hit F12 in error and it has booted to a choice of windows 10 with a countdown of 10 seconds or Macrium reflect. I dont know how to get rid of this. Was thinking of resetting win 10 but am not sure if this would help? yours Norman.
« Reply #43 on: March 29, 2018, 11:07:27 pm »
If you enter the BIOS, and go to the "Security" tab
then select "Select a UEFI file as trusted for executing" .. then hit enter.
then select "<EFI>" .. and hit enter
is "<ubuntu>" listed ?
if so select "<ubuntu>" .. and hit enter
then select "shimx64.efi" .. and hit enter.
then when asked if you want to "add a new file", type Peppermint .. then select "YES"
Then save the BIOS and exit.  <-- IMPORTANT
There's a video here:
https://www.youtube.com/watch?v=cVbUrzYD8PE
« Last Edit: March 29, 2018, 11:10:30 pm by Mark Greaves (PCNetSpec) »
« Reply #44 on: April 05, 2018, 02:05:31 pm »
Hi Mark thanks for your patience. I entered the bios as per your instructions, but when selecting a eufi file as trusted for executing and pressing enter
the only option showing is HDD0? You must be getting a bit sick of my ignorance, I think in future I shall not be dual booting. Yours Norman.
