Author Topic: [SOLVED] Installed Oracle VM - Problem 'Seeing' USB Devices  (Read 1379 times)
Offline pooky2483
« on: February 27, 2018, 08:33:26 pm »
As the title says, I am unable to 'see' any USB device.
How do I fix the problem?
The VM is installed on my desktop PC. The VM I'm trying to get to 'see' the USB devices is Kubuntu 16.04.
« Last Edit: March 02, 2018, 01:34:18 pm by pooky2483 »
Re: Installed Oracle VM - Problem 'Seeing' USB Devices
« Reply #1 on: February 27, 2018, 11:57:30 pm »
Oracle VM ?
Are you talking about "Oracle Virtualbox" or "VMware Player" ?
If Virtualbox, what's the output from
dpkg -l | grep virtual
« Last Edit: February 28, 2018, 12:17:27 am by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #2 on: February 28, 2018, 09:23:44 pm »
Sorry Mark, I meant Virtualbox when I said Virtual Machine, just habit I suppose.
The result I get is;
(click to show/hide)
« Reply #3 on: February 28, 2018, 11:48:21 pm »
You need to add yourself to the vboxusers group .. then log off/on
Shut down all VM's, and close Virtualbox
Open a terminal and run:
sudo adduser $USER vboxusers
Now log off and on again (or reboot)  <-- IMPORTANT
Now fire up a Virtualbox VM, and you should be able to activate a USB device on the bottom panel of Virtualbox.
Offline pooky2483
« Reply #4 on: March 01, 2018, 03:08:48 pm »
That fixed it Mark. I tried following a video on YouTube and that is one thing they missed out.
« Reply #5 on: March 01, 2018, 04:58:43 pm »
Can you please remember to mark the topic (SOLVED) ;)
