Author Topic: [SOLVED] Unable to create new VB after deleting old VB  (Read 1814 times)
Offline pooky2483
« on: March 02, 2018, 01:42:21 pm »
I am unable to select an ISO after creating a virtualbox OS and then deleting it, then creating tone with the same name, I don't get the option to select an ISO as the set-up skips that step and goes straight into trying to boot.
« Last Edit: March 03, 2018, 12:50:01 pm by pooky2483 »
Offline pooky2483
Re: Unable to create new VB after deleting old VB
« Reply #1 on: March 02, 2018, 02:23:45 pm »
I am now unable to select an ISO for ANY VB machine I create as the step to select an ISO is skipped and pre process goes straight to booting up the OS.
Offline pooky2483
« Reply #2 on: March 02, 2018, 05:08:31 pm »
I think I've found a bug.
I can create a VB OS, say Ubuntu 16.04 and then change settings to suit, select the OS ISO and run it as a normal OS.
I then delete the VB and try to create the same VB OS again, with the same name.
What happens is I don't get the option of choosing the OS ISO, it just continues on and reports an error that there's no OS.
« Reply #3 on: March 02, 2018, 05:16:25 pm »
Dunno if that's a bug, but if it is you're reporting it in the wrong place.
Why not just mount the ISO via the VM settings ?
If you don't mind loosing any already created VM's you could always delete the VirtualBox config directories .. which will set Vbox back to defaults
« Last Edit: March 02, 2018, 05:23:01 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #4 on: March 02, 2018, 11:36:41 pm »
I know this aint the place to report bugs, I was just bringing it up that I think it's a bug.
I've figured how to get around it.
When I create a VB and then delete it for some reason and create it again, I leave all the settings alone until I've actually created the VB and selected the ISO.
I don't quite get you when you say "Why not just mount the ISO via the VM settings ?"
« Reply #5 on: March 03, 2018, 12:28:30 am »
Offline pooky2483
« Reply #6 on: March 03, 2018, 12:49:10 pm »
Ah, I get you now.
I didn’t realise I could install the OS that way, I just thought it was to access the CD/DVD drive.
