Author Topic: where has .usr\share gone  (Read 1799 times)
Offline donwatson
  • Getting older
« on: March 02, 2018, 11:24:12 pm »
Hi,
I am looking for the usr/share/inkscape/extensions file but can't find the usr folder to get started what have I done wrong ??
Novatech build
External 2TiB HD
Re: where has .usr\share gone
« Reply #1 on: March 03, 2018, 12:14:51 am »
Dunno because you've neither explained what you were doing .. where you were doing it (terminal/file manager/etc.) .. or what went wrong (for example, "when I browser there in the file manager that directory doesn't exist", or maybe "when I run ls usr/share/inkscape/extensions in a terminal it returns that the directory doesn't exist", etc.).
The title of this topic is confusing me even more .. it has a "." in it, and a "\" backslash ???
( a directory with "." at the beginning of its name would be hidden, and backslashes are not used it Linux paths)
If you mean you're entering sometthing like
in a terminal and it's saying it doesn't exist .. that would be because you missed out the leading "/" .. it should read
ls /usr/share/inkscape/extensions
If it's any other problem you'll need to explain.
BTW, /usr/share/inkscape/extensions is a directory, not a file.
« Last Edit: March 03, 2018, 12:03:20 pm by Mark Greaves (PCNetSpec) »
Offline donwatson
  • Getting older
« Reply #2 on: March 03, 2018, 10:38:49 am »
Thanks Mark for that quick reply.
I am indeed trying to add 2 extensions to Inkscape, one will let me export Gcode that I can use for the raster images and the other will let me export Gcode for the vector images.
I will carry on now and see what transpires.
take care
Don W
Novatech build
External 2TiB HD
Offline donwatson
  • Getting older
« Reply #3 on: March 03, 2018, 01:43:46 pm »
Mark,
I have tried to put files into the Inkscape/extensions directory without success.
I have the files in a .zip file and have extracted them {/home/don/My_Setups/jtp_extension/JTP_Laser_Tool_V1_4.zip} but I can't move/copy/paste them at all.
When I get to the extensions folder the option to Paste is greyed out. Have I missed a step ??
Novatech build
External 2TiB HD
« Reply #4 on: March 03, 2018, 03:00:10 pm »
You don't have permission to write to that directory .. open the file manager as root.
I can't tell you the exact command or GUI procedure as you haven't mentioned which Linux you are using.
If it's Peppermint 7 (as in your signature), open the file manager and navigate to
/usr/share/inkscape
then right-click on the extensions folder and select "Open as root".
Or just fire up the Nemo file manager as root already at that directory
gksudo nemo /usr/share/inkscape/extensions
« Last Edit: March 03, 2018, 03:04:40 pm by Mark Greaves (PCNetSpec) »
Offline donwatson
  • Getting older
« Reply #5 on: March 03, 2018, 04:37:42 pm »
Thanks for that Mark,
As ever you have came up with the goods.
I have run Inkscape and produced the Gcode for the first very simple project.
I can't try it out as the Laser engraver is out of reach (at the bottom of the garden) :'( but hopefully the weather will ease up soon.
take care
Don W
Novatech build
External 2TiB HD
