Author Topic: How do I get rid of Pep 8 from my dual boot (Solved)  (Read 2597 times)
Offline donwatson
  • Getting older
« on: March 26, 2018, 01:08:19 pm »
Is there an easy way to get rid of Peppermint 8 from my dualboot Pep 7 and Pep 8 system ??
Don W
« Last Edit: March 26, 2018, 10:16:37 pm by donwatson »
Novatech build
External 2TiB HD
Re: How do I get rid of Pep 8 from my dual boot
« Reply #1 on: March 26, 2018, 01:18:22 pm »
Boot into Peppermint 7, and post the output from:
sudo fdisk -l
sudo blkid
mount
if it's Peppermint 8 you want to get rid of, make sure you post the output from those commands whilst booted into Peppermint 7
Offline donwatson
  • Getting older
« Reply #2 on: March 26, 2018, 01:28:12 pm »
Hows this ?
don@ldwatson ~ $ sudo fdisk -l
[sudo] password for don:
Disk /dev/sda: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: gpt
Disk identifier: DE608926-D903-482F-BE6E-3EA72F89AD5B
Device         Start       End   Sectors   Size Type
/dev/sda1       2048   1050623   1048576   512M EFI System
/dev/sda2    1050624 623449576 622398953 296.8G Linux filesystem
/dev/sda3  968998912 976771071   7772160   3.7G Linux swap
/dev/sda4  623450112 968998911 345548800 164.8G Linux filesystem
Partition table entries are not in disk order.
don@ldwatson ~ $ sudo blkid
/dev/sda1: UUID="D39E-DA25" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="49d5d369-b448-4103-a2f8-c7cc1c874dc3"
/dev/sda2: UUID="15ac0596-d7f7-471d-803e-f7897fc7d3a7" TYPE="ext4" PARTUUID="a6682da6-640c-44ce-a943-d2d9dab8b3fd"
/dev/sda3: UUID="f404b181-4780-438e-8339-d9c680635f94" TYPE="swap" PTUUID="87d04b65" PTTYPE="dos" PARTUUID="22a2c3f7-49e7-4a5b-bc76-d16f7e61eb7e"
/dev/sda4: UUID="a6ae7f58-1daa-4b8c-baee-cda572e74a1f" TYPE="ext4" PARTUUID="f8f7a69a-7985-4dc6-ace1-963797b9423f"
don@ldwatson ~ $ mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=1849992k,nr_inodes=462498,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=374380k,mode=755)
/dev/sda2 on / type ext4 (rw,relatime,errors=remount-ro,stripe=32748,data=ordered)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=25,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
/dev/sda1 on /boot/efi type vfat (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=374380k,mode=700,uid=1000,gid=1000)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
don@ldwatson ~ $
Novatech build
External 2TiB HD
« Reply #3 on: March 26, 2018, 01:59:16 pm »
Okay, basically you need to boot to a LiveUSB .. then use Gparted to
a) delete /dev/sda4 (which is the Peppermint 8 partition)
b) move /dev/sda3 to the end of the drive (sda3 is the swap partition, moving it to the end of the drive will leave room to expand sda2 into, sda2 being the Peppermint 7 partition)
c) expand (NOT move) /dev/sda2 into the free space (so the now free space is available to Peppermint 7)
If I were you, I'd create a LiveUSB, boot to it. fire up GParted and take a look at the partition layout, and make sure you understand what I just suggested BEFORE actually doing it.
Offline donwatson
  • Getting older
« Reply #4 on: March 26, 2018, 02:49:58 pm »
I carried out those suggestions and it looked as if everything was well.
I logged out and logged back in and got this message
GNU GRUB  version 2.02~beta2-36ubuntu3.17
Minimal BASH-like line editing is supported.
For the first word, TAB lists possible command completions.
Anywhere else TAB lists possible device or file completions
Any ideas ?
Novatech build
External 2TiB HD
« Reply #5 on: March 26, 2018, 05:38:34 pm »
Are you able to select "ubuntu" from the EFI boot selection screen ?
if you don't know how to get to the EFI boot selection screen, what make/model is your laptop ?
« Reply #6 on: March 26, 2018, 05:45:24 pm »
Boot to a Peppermint 7/8 64bit LiveUSB and run these commands in sequence:
sudo mount /dev/sda2 /mnt
sudo mount /dev/sda1 /mnt/boot/efi
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
sudo chroot /mnt
grub-install /dev/sda
update-grub
then hit Ctrl+D to exit the chroot environment
and reboot to test.
Offline donwatson
  • Getting older
« Reply #7 on: March 26, 2018, 07:36:36 pm »
Thanks Mark,
That did the trick  :D :D
It was a bit cheek clenching entering those commands manually but all is well again.
Thanks again, great karma.
Don W
Novatech build
External 2TiB HD
« Reply #8 on: March 26, 2018, 07:55:53 pm »
Glad I could help .. can you please remember to mark the topic (SOLVED) Don ;)
