Author Topic: remove the dual boot Win10 and Peppermint 8  (Read 2985 times)
Offline donwatson
  • Getting older
« on: April 21, 2018, 09:57:02 am »
I have an Acer Aspire 5732Z that dual boots Windows 10 and Peppermint 8. I want to remove the Peppermint 8 and leave the Win 10 setup for my grandson.
Is there an easy way to remove Peppermint 8 ??
Don W
EDIT This is very cheeky I think as it is really a Windows problem ??
Novatech build
External 2TiB HD
Re: remove the dual boot Win10 and Peppermint 8
« Reply #1 on: April 21, 2018, 12:04:35 pm »
Is it a UEFI system ?
If you boot into Peppermint, what's the output from:
efibootmgr -v
Offline donwatson
  • Getting older
« Reply #2 on: April 21, 2018, 05:46:34 pm »
It says "The program 'efibootmgr' is currently not installed. You can install it by typing sudo apt install efibootmgr"
Novatech build
External 2TiB HD
« Reply #3 on: April 21, 2018, 05:56:06 pm »
Okay does running:
[ -d /sys/firmware/efi ] && echo UEFI || echo BIOS
return UEFI or BIOS ?
If UEFI, install efibootmgr:
sudo apt-get install efibootmgr
and post the output from
efibootmgr -v
Offline donwatson
  • Getting older
« Reply #4 on: April 22, 2018, 10:56:00 am »
It returns BIOS
don@ldwatson ~ $ [ -d /sys/firmware/efi ] && echo UEFI || echo BIOS
BIOS
don@ldwatson ~ $
EDIT and
don@ldwatson ~ $ efibootmgr -v
The program 'efibootmgr' is currently not installed. You can install it by typing:
don@ldwatson ~ $
Does this help ?
« Last Edit: April 22, 2018, 03:29:41 pm by donwatson »
Novatech build
External 2TiB HD
« Reply #5 on: April 23, 2018, 01:43:15 pm »
Okay it appears to have been installed in legacy BIOS mode which makes things more difficult.
If you remove Linux now, you'll not be able to boot Windows unless you reinstall the Windows bootloader.
Do you have a Windows installation disk ? .. and if not, is Win10 32bit or 64bit ?
Offline donwatson
  • Getting older
« Reply #6 on: April 23, 2018, 04:25:49 pm »
The windows spec. is "Windows 10 Home, Version 1709, OS Build 16299.371.
It was installed by up dating  (free) from Win 7.
I can leave it alone if this is going to cause a problem.
EDIT No, there is no installation disc. I have the 'Version number and the OS Build number" for the windows installation. ??
« Last Edit: April 23, 2018, 04:29:12 pm by donwatson »
Novatech build
External 2TiB HD
Offline wishbone
« Reply #7 on: April 23, 2018, 07:56:51 pm »
On the odd occasion that I`ve lost the ability to boot, I use "boot repair disc" and so far it`s worked a treat.
https://sourceforge.net/p/boot-repair/home/Home/
https://sourceforge.net/projects/boot-repair-cd/files/
If it`s any help.
