Author Topic: login problem Peppermint 8 (SOLVED)  (Read 7745 times)
Offline normanliddle
« on: April 22, 2018, 06:35:19 pm »
To: Some one who knows? After dual booting Peppermint 8 with Win 10 (Mark Greaves did it really) I changed the login sequence to not need a password which
I shall not be doing again when this is sorted. I'm writing this post in Win 10. When I try to access Peppermint 8 I'm in a permanent loop at the login screen. I also cannot connect to the internet as a guest user so will have to answer hopefully your replies through Win 10 or through Peppermint 8 on an asus eeepc.
Yours sincerely, Norman Liddle.
« Last Edit: June 06, 2018, 11:29:30 pm by normanliddle »
Offline donwatson
  • Getting older
Re: login problem Peppermint 8
« Reply #1 on: April 22, 2018, 09:14:14 pm »
Sorry I can be of no help Norman.
I am running a perfectly good Peppermint 8 alongside Windows 10 that my grandson uses. He needs more room and I don't need access to Pep 8 now so I want rid of Pep 8. So it looks as if we have opposite problems. I am sure Mark will be along soon and sort us all out.
I have had my grandson visiting since Saturday evening so I haven't been able to access until now.
take care
Don W
EDIT Forgot to say that I usually have a look back through the threads here as someone else may have experienced the problem before. You can get a good idea of what to do that way.
« Last Edit: April 22, 2018, 09:17:33 pm by donwatson »
Novatech build
External 2TiB HD
« Reply #2 on: April 23, 2018, 01:39:39 pm »
Can you explain how you did that ?
« Reply #3 on: April 23, 2018, 10:51:33 pm »
I access the users and groups window in peppermint 8. I ticked the button/icon to not need to login with a password. Rebooted but still had to login
with a password? So in the users and groups I deleted the password in the first field? an error on my behalf I think? and re ticked the button/icon to
not login with a password.
I'm hoping Mark that I can reset the password from the terminal window in the guest session? but have not yet learnt the syntax or commands in
the terminal command line. I looked through the FAQ posts and old posts regarding passwords but could only find posts relating to Linpus Lite which
you mentioned would probably not work in ubuntu distros. I'm posting this from an asus eepc as the guest session on the acer has no internet access?
I don't know why as the main session which I am locked out of has internet access. Yours sincerely, Norman Liddle.
« Reply #4 on: April 24, 2018, 05:00:01 am »
You cannot fix this from the guest account as it doesn't have 'sudo' permission.
I'll post instructions how to log into single user mode and change your password tomorrow .. bit late tonight.
« Reply #5 on: April 24, 2018, 03:31:33 pm »
Okay, to reset your password...
You need to boot into 'recovery mode', so turn off your computer .. then turn it on again.
Once at the GRUB menu use the down arrow key to select the "Advanced" menu item, and hit enter.
Select the first entry that ends with "(recovery mode)" and hit enter.
You should now be presented with a with a few options .. select the option "root   Drop to a root shell prompt" and hit enter.
When you end up at an # prompt, run:
mount -o rw,remount /
(that's a comma between rw and remount)
passwd username
where 'username' is your actual system username .. if you're not sure what your username is, running
ls /home
may give you a clue.
When you run the 'passwd' command you will be asked for a new password .. enter it, and hit enter .. you will be prompted for it again .. enter it again and hit enter.
(be aware, when typing the password nothing will be echoed to screen but it **is** going in)
When done, reboot with:
shutdown -r now
then use your new password to login.
One you're back in, let me know and i'll tell you how to set autologin if you want.
« Last Edit: April 24, 2018, 03:36:18 pm by Mark Greaves (PCNetSpec) »
« Reply #6 on: April 25, 2018, 01:45:06 pm »
Hi Mark, cannot get passed the first command re: special device remount does not exist? any help is appreciated. will keep trying after this post.
Yours Norman.
« Reply #7 on: April 25, 2018, 02:17:21 pm »
Are you sure you're entering the command properly, with the comma between rw and remount .. and the -o being a lower case O (not a zero)
The command is
mount<space>-o<space>rw<comma>remount<space>/
« Reply #8 on: April 25, 2018, 02:36:39 pm »
Hi Mark, have now passed the re-enter password stage but still cannot login I have changed the password twice but to no avail. As I am typing the
system takes over and does its own thing is, there a time limit to enter commands? Also initially I am asked after entering root is it (maintenance or
continue) when I press control&D to continue it gives a menu to continue to normal boot so I just go with maintenance? After confirming the password the system jumps to the original menu options ? I have not been able to use the shutdown -r now command from the #prompt. yours Norman.
ps have to go now but will continue thanks for the help.
« Reply #9 on: April 25, 2018, 04:31:58 pm »
Don't hit Crtl+D .. hit Enter, which should leave you at an # prompt.
« Reply #10 on: April 25, 2018, 07:34:34 pm »
Hi Mark, I will know these commands shortly by not looking at your data. I am now at the stage where the prompts are telling me that the password
has been updated successfully, but when I start to type (shutdown  -r now) the system scrolls with a load of data. When I do manage to reboot the system
usually by holding down the power on key, because every thing appears to have locked up. Yours  norman.
« Reply #11 on: April 25, 2018, 07:48:10 pm »
Hi Mark, apologies for being a pain, have just completed your instructions without a hitch even rebooted successfully with (shutdown -r now)
But when I try to login with the new password there is no option(my user name is above the login window so I know that is correct,all I have is
log in but when I try to enter the password it just does not want to know? Yours Norman.
« Reply #12 on: April 25, 2018, 10:21:30 pm »
What happens if you get to the login screen, then hit Ctrl+F2 to drop to a consle...
then log in in text mode...
then run:
sudo service lightdm restart
« Reply #13 on: April 26, 2018, 07:27:18 am »
Hi Mark, nothing happens at the login screen using Control and F2, Yours Norman.
« Reply #14 on: April 26, 2018, 01:17:01 pm »
Sorry Norman, typo .. I mean Ctrl+Alt+F2
