Author Topic: login problem Peppermint 8 (SOLVED)  (Read 7744 times)
Re: login problem Peppermint 8
« Reply #30 on: June 06, 2018, 10:04:43 pm »
It's your topic my mate, you have to do it ;)
Edit the FIRST post in this topic and change:-
Subject: login problem Peppermint 8 (SOLVED)
