Author Topic: [SOLVED] Unable to install the GUI for Testdisk/QPhotorec  (Read 6940 times)
Offline pooky2483
« on: May 14, 2018, 10:57:55 pm »
I've installed testdisk and searched for an answer on how to install the gui but was unable to find the solution.
I found THIS thread but even after trying it, I get a warning that it's not production ready!!!
Even though I click on the 'OK', the program stops.
Is there any way I can get the GUI installed?
« Last Edit: May 24, 2018, 11:30:46 am by pooky2483 »
Re: Unable to install the GUI for Testdisk/QPhotorec
« Reply #1 on: May 16, 2018, 02:18:05 am »
open a terminal and run these commands in sequence
*these commands were tested in 16.04, not 14.04 as your signature suggests .. but I guess they'll work)
First let's uninstall testdisk if you already have it installed, because wwe'll be installing the latest version
sudo apt-get remove purge testdisk
now to get/build/install the lastest version (which includes QPhotoRec), run:
sudo apt-get install -y build-essential linux-headers-generic e2fslibs-dev libncurses5-dev libncursesw5-dev ntfs-3g-dev libjpeg-dev uuid-dev zlib1g-dev qtbase5-dev qttools5-dev-tools pkg-config dh-autoreconf git
mkdir ~/photorec-7.1-install-dir
cd ~/photorec-7.1-install-dir
git clone https://github.com/cgsecurity/testdisk.git
cd ~/photorec-7.1-install-dir/testdisk
mkdir config
autoreconf --install -W all -I config
./configure
make
sudo make install
you'll now have to edit the launcher before it shows up in the menus, and so it uses gksudo to gain the elevated privileges it requires to run .. so run:
sudo kate /usr/local/share/applications/qphotorec.desktop
(replace kate in that command if you're using a different text editor)
and change the file to read:
[Desktop Entry]
Type=Application
Version=1.0
Name=QPhotoRec
GenericName=Data Recovery Utility
Icon=qphotorec
TryExec=/usr/local/bin/qphotorec
Exec=gksudo /usr/local/bin/qphotorec %F
Terminal=false
Categories=System;Filesystem;Qt;
then SAVE the file
QPhotoRec should now be in your menu.
Okay that's how to install it .. but I can offer no comment on whether it's any good or whether it'll nuke your system, so you USE AT YOUR OWN RISK.
« Last Edit: May 16, 2018, 02:19:49 am by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #2 on: May 16, 2018, 08:45:20 pm »
I managed to get qphotorec working.
I had to further edit qphotorec.desktop and change the GKSUDO to just SUDO (GKSUDO would not work), which calls something up, which then disappears straight away.
In the end, I have to call it in terminal using
sudo qphotorec
[Desktop Entry]
Type=Application
Version=1.0
Name=QPhotoRec
Icon=qphotorec
Exec=sudo /usr/local/bin/qphotorec %F
Terminal=false
Theres also a menu entry for Testdisk which does not work, again, I have to call it using
sudo testdisk
Thanks for at least getting it installed :-)
« Last Edit: May 16, 2018, 08:54:31 pm by pooky2483 »
« Reply #3 on: May 16, 2018, 10:05:22 pm »
I keep forgetting you run KDE
change "gksudo" to "kdesudo"
I'm also betting that the testdisk launcher is pointing at /usr/bin/testdisk .. yet testdisk got installed to /usr/local/bin/testdisk .. so you'll need to modify its launcher too.
Offline pooky2483
« Reply #4 on: May 17, 2018, 04:27:50 pm »
I'm having trouble finding the testdisk launcher, all I can find is in the screenshot...
« Reply #5 on: May 17, 2018, 10:45:08 pm »
run
sudo updatedb
now what's the output from:
locate -i testdisk
Offline pooky2483
« Reply #6 on: May 18, 2018, 12:22:40 pm »
locate -i testdisk
(click to show/hide)
Offline pooky2483
« Reply #7 on: May 18, 2018, 12:23:19 pm »
This is the second part of the results as it was too big to fit in one message...
Re: [SOLVED] Unable to install the GUI for Testdisk/QPhotorec
« Reply #8 on: May 25, 2018, 12:41:55 pm »
testdisk is a command line utility, so won't have a "launcher" .. it's what the QPhotoRec GUI front end is using in the background.
Command line utilities don't have menu items, or you'd have a VERY full menu ;)
