Author Topic: Upgrading to new kit  (Read 1406 times)
Offline Rich J
  • Sr. Member
  • A Linux Luvvie!
« on: May 21, 2018, 07:47:50 am »
Hi All - I'm thinking of replacing my aged desktop for something more current and would appreciate advice?
It will be for basic 'home computing' - no gaming or heavy streaming/video editing use etc etc.  Something like a 500GiB SSD, minimum 4GiB Ram, SATA, DVD writer, Wireless and so on.  No O/S required - it will be a pure Linux box.
I'm ok for the monitor and have a DVD writer in the current rig that I could swap out but writers are cheap these days anyway if needs be.  A new (wired) keyboard and mouse would be handy too.
Any preferences between Intel or AMD processors?  Any preferences regarding makes of motherboard - particularly in terms of Linux installation?
I'm currently drawn towards stuff from Scan and/or Novatech which seem cheap enough but I'm also happy to get the parts and do a self build.
If any of you have already gone down this route, any advice re: building snags or stuff to watch out for or to avoid would be welcome!
Regards
Rich
Re: Upgrading to new kit
« Reply #1 on: May 25, 2018, 12:44:38 pm »
It'd probably be better if you posted the make/model of hardware you're considering .. then we can try check if there are any known issues.
