Author Topic: A "grep" problem  (Read 1839 times)
A "grep" problem
« on: May 25, 2018, 03:40:17 pm »
Consider:
keith@T500:~$ q=$(ls | grep dEsktop)     (i.e. a non-existent file)
keith@T500:~$ echo $q
keith@T500:~$
I want to test the value of "q" for its null value here.  It's not " " or "", so what might it be?
Can anyone help?
Re: A "grep" problem
« Reply #1 on: May 25, 2018, 07:49:00 pm »
Found it at: https://serverfault.com/questions/7503/how-to-determine-if-a-bash-variable-is-empty
For a variable q:
               if [ -z "$q" ]; then ......
will detect if the variable is unset or the empty string "".
