Author Topic: Setting the terminal position  (Read 3608 times)
« on: June 12, 2018, 08:27:29 pm »
I have a script that I run from an exisitng terminal that changes, inter alia, the current terminal size.  But it would be nice also to reposition the terminal on the screen.
I have found the command gnome-terminal --geometry COLSxROWS1+X+Y but this, as one might expect, opens a new terminal at the desired position.
Is there a way to reposition the current terminal from within the script?
Re: Setting the terminal position
« Reply #1 on: June 13, 2018, 07:57:27 pm »
So you don't mean screen position, you mean terminal SIZE ?
You also haven't mentioned distro/version/architecture .. or desktop environment
« Last Edit: June 13, 2018, 07:59:34 pm by Mark Greaves (PCNetSpec) »
« Reply #2 on: June 13, 2018, 09:42:42 pm »
Sorry once more:  This is a Lenovo Thinkpad T500 running Ubuntu 16.04 in Classic View.
Err, no:  I mean the position of the terminal window on the screen.
I can change the size of the current (only) working terminal window (resize -s rows cols) and I want to change its position, too.  i.e. automatically, within the script, rather than manually moving the terminal window with the mouse.
This isn't important, of course - it's just for tidiness.  And laziness.  And fun.
« Last Edit: June 13, 2018, 09:44:15 pm by Keith »
« Reply #3 on: June 14, 2018, 01:06:11 am »
Ah I see .. but not that I know of :(
« Reply #4 on: June 14, 2018, 12:45:44 pm »
Thanks anyway, Mark.    Sorry to have troubled you.
« Reply #5 on: October 14, 2018, 06:40:50 pm »
The command wmctrl has the ability to specify both the size and position of the current terminal (or indeed, any window) on the screen.
It works well.
