Author Topic: Brother DCP1610W Scanner - [Not Solved, Question Too Idiotic]  (Read 1855 times)
Offline ahead
  • Full Member
Hello, I've recently bought a Brother DCP1610W mono laser printer/scanner, I am using Mint 17.3 Rosa. The printer works perfectly via WiFi but I can' get the scanner to work either via USB or WiFi. Please help!
« Last Edit: September 04, 2018, 07:58:47 pm by ahead »
Re: Brother DCP1610W Scanner
« Reply #1 on: June 14, 2018, 01:10:09 am »
What have you already tried ?
Offline ahead
  • Full Member
« Reply #2 on: June 21, 2018, 11:40:45 am »
Well...I've tried to scan.
Sorry, I don't understand what you are asking. Perhaps I should re-word the question; How do I check that I have installed the scanner drivers correctly, if they are wrong or missing how should I remedy the problem, please?
Offline ahead
  • Full Member
« Reply #3 on: June 26, 2018, 07:56:41 am »
Ah well, thanks for looking anyway.  :(
