Author Topic: Nemo file manager won't display the Rubbish Bin [SOLVED]  (Read 1706 times)
« on: July 04, 2018, 01:49:52 pm »
Lenovo Thinkpad T500 laptop running Ubuntu 16.04
I've been using Nemo as my default file manager for some time as I find it much better than the newer versions of Nautilus despite having a few quirks.
I find now that when trying to display the Rubbish Bin Nemo displays it very briefly then promptly crashes.
I have tried removing the application, along with its *.desktop files in ~/.local/share/applications, then re-installing, but all to  no avail.  Strangely; re-installation did not re-create the *.desktop files.
Not being able to display the Rubbish Bin isn't the end of the world, as I still have Nautilus, but it is rather annoying and I would be grateful for advice.
Thank you
« Last Edit: July 05, 2018, 02:31:36 pm by Keith »
Re: Nemo file manager won't display the Rubbish Bin
« Reply #1 on: July 05, 2018, 02:01:33 pm »
Try running:
sudo mv -v ~/.local/share/Trash ~/.local/share/Trash.broken
Is the problem that there's no trash on the desktop, or in Nemo itself ?
« Reply #2 on: July 05, 2018, 02:25:19 pm »
That fixed the problem, Mark.
There was indeed a Rubbish Bin listed under "My Computer" - as there is in Nautilus - but Nemo crashed when selecting it, although Nautilus opened it OK.
Renaming the Trash directory forced its re-creation.  I guess I must have damaged the original Trash directory whilst fiddling with the system.  So no change there, then.
Many thanks as usual.
[EDIT]  Trash on the desktop?  I don't think I've ever seen it there.
« Last Edit: July 05, 2018, 02:28:01 pm by Keith »
« Reply #3 on: July 06, 2018, 03:50:59 pm »
It's not there by default but you can add it if you wish
along with any of
Home
Computer
Mounted Volumes
Re: Nemo file manager won't display the Rubbish Bin [SOLVED]
« Reply #4 on: July 06, 2018, 03:54:49 pm »
I'm not sure that I need that facility but I am curious to know how it's done in case any of my friends prefer it.
Can you oblige, please?
« Reply #5 on: July 06, 2018, 08:45:10 pm »
Fire up dconf-editor
Menu > System > dconf-Editor
In the left hand pane navigate to
org > nemo > desktop
you can then (in the right hand pane toggle on/off any of
computer-icon-visile
home-icon-visible
network-icon-visible
trash-icon-visible
volumes-visible
I'd suggest you're careful in there and don't change anything else unless you know what you're doing ;)
« Reply #6 on: July 06, 2018, 09:05:38 pm »
Mark, I rarely know what I am doing!  So I am sorely tempted to .....er.... leave things alone.
However, I did find this link that gives a very good description of dconf and how to use it  ( https://askubuntu.com/questions/22313/what-is-dconf-what-is-its-function-and-how-do-i-use-it) that our readers might find useful.
I shall install dconf-editor and look around but shan't dabble until I am sure of my ground - I take your warnings to heart.
Thank you, Mark.
