Author Topic: peppermint 9 on hp550 with 128 gb ssd  (Read 1680 times)
Offline Jacob
« on: July 27, 2018, 09:17:30 pm »
Today i installed peppermint all went well, but it takes 4 minutes to boot up  >:(
i have no idea. :(
Had the same problem with an macbook 4.1, with other linux distributions, after a few days trying, i was so mad that i smashed the mac, it is now in the trashcan
so this could become the next candidate.
Re: peppermint 9 on hp550 with 128 gb ssd
« Reply #1 on: July 27, 2018, 10:21:41 pm »
What's the output from:
sudo fdisk -l
sudo blkid
cat /etc/fstab
cat /etc/initramfs-tools/conf.d/resume
systemd-analyze critical-chain
systemd-analyze blame
Offline Jacob
« Reply #2 on: July 27, 2018, 10:26:57 pm »
now brought it back to 45 seconds
i did this:
This is a bug basically a broke driver try to remove the Intel x86 Driver package with
sudo apt-get remove xserver-xorg-video-intel
and this
xed admin:///etc/default/grub
Modify the line there as:
GRUB_CMDLINE_LINUX_DEFAULT="video=SVIDEO-1:d quiet splash"
Save. Then sudo update-grub & reboot...
