systemd-analyze blame: 12.008s systemd-journal-flush.service 10.898s dev-mapper-mint\x2d\x2dvg\x2droot.device 8.885s lvm2-monitor.service 8.014s systemd-tmpfiles-setup-dev.service 7.281s systemd-sysctl.service 5.526s networkd-dispatcher.service 4.792s udisks2.service 4.723s NetworkManager.service 4.586s ubuntu-system-adjustments.service 4.059s ModemManager.service 4.009s accounts-daemon.service 3.147s thermald.service 2.991s grub-common.service 2.198s keyboard-setup.service 1.860s polkit.service 1.777s wpa_supplicant.service 1.726s systemd-modules-load.service 1.517s rsyslog.service 1.466s lightdm.service 1.463s plymouth-quit-wait.service 1.260s [email protected]:1.service 1.228s avahi-daemon.service 1.106s bluetooth.service 1.082s systemd-random-seed.service 1.075s networking.service 1.071s apport.service 965ms apparmor.service 771ms systemd-tmpfiles-setup.service 762ms lm-sensors.service 745ms kerneloops.service 709ms systemd-udevd.service 678ms dev-hugepages.mount 632ms dns-clean.service 628ms systemd-remount-fs.service 597ms sys-kernel-debug.mount 591ms gpu-manager.service 590ms dev-mqueue.mount 567ms systemd-logind.service 543ms systemd-resolved.service 397ms geoclue.service 386ms upower.service 333ms systemd-journald.service 325ms packagekit.service 302ms systemd-rfkill.service 295ms rtkit-daemon.service 288ms setvtrgb.service 272ms kmod-static-nodes.service 234ms blk-availability.service 229ms ntp.service 197ms dev-mapper-mint\x2d\x2dvg\x2dswap_1.swap 181ms [email protected] 179ms systemd-timesyncd.service 162ms hddtemp.service 150ms systemd-update-utmp-runlevel.service 147ms speech-dispatcher.service 133ms systemd-udev-trigger.service 105ms systemd-tmpfiles-clean.service 94ms motd-news.service 85ms systemd-update-utmp.service 34ms ufw.service 22ms alsa-restore.service 19ms pppd-dns.service 16ms ureadahead-stop.service 16ms plymouth-start.service 16ms openvpn.service 13ms systemd-user-sessions.service 12ms plymouth-read-write.service 10ms [email protected]:acpi_video0.service 7ms console-setup.service 7ms sys-fs-fuse-connections.mount 3ms sys-kernel-config.mount
systemd-analyze critical-chain:The time after the unit is active or started is printed after the "@" character.The time the unit takes to start is printed after the "+" character.graphical.target @23.815s??multi-user.target @23.815s ??getty.target @23.815s [email protected] @23.814s ??system-getty.slice @23.813s ??setvtrgb.service @23.524s +288ms ??systemd-user-sessions.service @22.034s +13ms ??network.target @22.026s ??NetworkManager.service @17.302s +4.723s ??dbus.service @17.068s ??basic.target @17.067s ??sockets.target @17.067s ??cups.socket @17.067s ??sysinit.target @17.044s ??systemd-timesyncd.service @16.865s +179ms ??systemd-tmpfiles-setup.service @16.078s +771ms ??systemd-journal-flush.service @4.067s +12.008s ??systemd-remount-fs.service @3.436s +628ms ??systemd-journald.socket @3.357s ??system.slice @3.355s ??-.slice @3.340s
blkid:/dev/sda1: UUID="tC64N9-pkWV-oQ2c-55Qb-xzvh-BcUy-wH5536" TYPE="LVM2_member" PARTUUID="12a0df2d-01"/dev/mapper/mint--vg-root: UUID="b1318e92-ec1c-4b24-afa7-3e2a36829efd" TYPE="ext4"/dev/mapper/mint--vg-swap_1: UUID="d49ba2e3-4b49-41dc-9b34-586150dfa505" TYPE="swap"
fstab:# /etc/fstab: static file system information.## Use 'blkid' to print the universally unique identifier for a# device; this may be used with UUID= as a more robust way to name devices# that works even if disks are added and removed. See fstab(5).## <file system> <mount point> <type> <options> <dump> <pass>/dev/mapper/mint--vg-root / ext4 errors=remount-ro 0 1/dev/mapper/mint--vg-swap_1 none swap sw 0 0
sudo dmesg | grep -i "error\|warn\|fail"
dmesg > ~/Desktop/dmesg.txt
[ <timestamp>] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:41:pipe B] flip_done timed out
sudo pluma /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash video=SVIDEO-1:d"
sudo update-grub
