Author Topic: Getting Started  (Read 4623 times)
Offline Ethel_Hallow
Getting Started
« on: September 08, 2018, 11:13:32 pm »
Hi everyone,
First, off my names, Chelsea and I'm re-entering the world of Linux after many years of using Mac OS and windows. may I ask a few questions?
I was just wondering what the best versions of Linux would be?
I will mainly be using it for the internet, word processing, some simple photo editing/viewing photos, viewing files, and general simple university work. I will probably load the software on an old accer laptop which is running an older generation processor though I will be upgrading the ram.
second question what version is similar to the layout of mac os, I been searching around and I'm currently liking the bottom access panel which is very user-friendly and clean look.
What version is this and where would be the safest place to download this from?
thanks kindly
Re: Getting Started
« Reply #1 on: September 09, 2018, 01:04:41 pm »
Hi Chelsea and welcome to the forum.
Older hardware, I'd have initially suggested Peppermint, and this can easily be modified to have an OS X style bottom dockbar.
But if you want that bottom dockbar 'out of the box', I'd probably suggest ElementaryOS.
https://peppermintos.com/
https://elementary.io/
(BTW, you can still get elementary for free .. just enter "custom amount" and set it to $0
