Author Topic: Libre Calc.  (Read 2571 times)
Offline Osmond
  • Full Member
Libre Calc.
« on: September 10, 2018, 03:15:50 pm »
Lbre Calc has been modified beyond description. I can no longer change font, number style, position in cell to name but a few. I can save which is rather academic since
 I cannot make any changes to my spreadsheet. Calc used to  be easy to use with options offering all the commonly used operations. What is going on?
Osmond
Re: Libre Calc.
« Reply #1 on: September 10, 2018, 03:30:10 pm »
Which version of Calc are you talking about ?
And in which distro/version ?
I can still do all the things you mentioned in Version: 6.0.3.2
Are you saying the option for changing font,etc. are missing .. or just not working ?
« Last Edit: September 10, 2018, 03:32:08 pm by Mark Greaves (PCNetSpec) »
Re: Libre Calc.
Offline Osmond
  • Full Member
Re: Libre Calc.
« Reply #2 on: September 10, 2018, 04:32:44 pm »
Don't know the version but I have recently downloaded a full set of updates including from Libre Office so should be up to date.
I cannot find the options mentioned.
Osmond
Re: Libre Calc.
« Reply #3 on: September 11, 2018, 12:08:26 am »
Where/how did you "download" the updates ?
And you can get the version by opening Calc, and going to Help > About LibreOffice
Offline Osmond
  • Full Member
Re: Libre Calc.
« Reply #4 on: September 11, 2018, 09:15:16 am »
This is Peppermint7. Recommended updates -small icon bottom right on screen. Generally update about once a month.
Version number 6.1 so far as I can see.
The option for changing "default font" is present but does not work. Have tried it many times. I cannot find the option for changing font on an open spreadsheet.
Hang on! Have just discovered "side bar" under "View" at the top of the spreadsheet window. This provides the operations I was missing. Libre Office is a very difficult system for the uninitiated to manage. Its "help" pages are not much help and it seems impossible to address a direct question.
Sorry to have troubled you. Thanks anyway.
Osmond
Re: Libre Calc.
Re: Libre Calc.
« Reply #5 on: September 11, 2018, 01:00:00 pm »
Hmm, you seem to have a more recent version than the default version in the Peppermint repos (more recent even than the version in Peppermint 9) .. maybe they've changed some stuff I'm not aware of yet.
Anyway, glad you figured it out :)
Offline Osmond
  • Full Member
Re: Libre Calc.
« Reply #6 on: September 11, 2018, 01:59:48 pm »
Unfortunately not to my satisfaction. Is it possible to get back to the earlier and much more usable version? I am spending a great deal of time grappling with cmplexities of this version and not getting any real work done. Grateful for any advice.
Re: Libre Calc.
« Reply #7 on: September 11, 2018, 02:33:33 pm »
What's the output from:
ls -a /etc/apt/sources.list.d
for APT in `find /etc/apt/ -name \*.list`; do grep -o "^deb http://ppa.launchpad.net/[a-z0-9\-]\+/[a-z0-9\-]\+" $APT | while read ENTRY ; do USER=`echo $ENTRY | cut -d/ -f4` PPA=`echo $ENTRY | cut -d/ -f5` ; echo ppa:$USER/$PPA ; done ; done
dpkg -l | grep libre
Offline Osmond
  • Full Member
Re: Libre Calc.
« Reply #8 on: September 15, 2018, 12:51:20 pm »
google-earth.list peppermint.list peppermint. list.save
I cannot get a response from your second sring. I continally get: bash: syntax error near unexpected token 'do'
The third response is: -l: command not found
« Last Edit: September 18, 2018, 11:25:20 am by Mark Greaves (PCNetSpec) »
Re: Libre Calc.
Re: Libre Calc.
« Reply #9 on: September 16, 2018, 01:29:41 am »
You're copying and pasting these commands right ?
Offline Osmond
  • Full Member
Re: Libre Calc.
« Reply #10 on: September 16, 2018, 11:25:08 am »
No. Just reading them and printing them manually.
Offline Osmond
  • Full Member
Re: Libre Calc.
« Reply #11 on: September 17, 2018, 10:51:50 am »
ppa:peppermintos/p7-release
This is what came up when copied and pasted your 2nd string
« Last Edit: September 18, 2018, 11:25:33 am by Mark Greaves (PCNetSpec) »
Offline Osmond
  • Full Member
Re: Libre Calc.
« Reply #12 on: September 17, 2018, 10:55:30 am »
ii  libdjvulibre-text                     3.5.27.1-5                                   all          Linguistic support files for libdjvulibre
ii  libdjvulibre21:amd64                  3.5.27.1-5                                   amd64        Runtime support for the DjVu image format
ii  libreadline5:amd64                    5.2+dfsg-3build1                             amd64        GNU readline and history libraries, run-time libraries
ii  libreadline6:amd64                    6.3-8ubuntu2                                 amd64        GNU readline and history libraries, run-time libraries
ii  libreoffice-base-core                 1:5.1.6~rc2-0ubuntu1~xenial4                 amd64        office productivity suite -- shared library
ii  libreoffice-calc                      1:5.1.6~rc2-0ubuntu1~xenial4                 amd64        office productivity suite -- spreadsheet
ii  libreoffice-common                    1:5.1.6~rc2-0ubuntu1~xenial4                 all          office productivity suite -- arch-independent files
ii  libreoffice-core                      1:5.1.6~rc2-0ubuntu1~xenial4                 amd64        office productivity suite -- arch-dependent files
ii  libreoffice-math                      1:5.1.6~rc2-0ubuntu1~xenial4                 amd64        office productivity suite -- equation editor
ii  libreoffice-style-elementary          1:5.1.6~rc2-0ubuntu1~xenial4                 all          office productivity suite -- Elementary symbol style
ii  libreoffice-style-galaxy              1:5.1.6~rc2-0ubuntu1~xenial4                 all          office productivity suite -- Galaxy (Default) symbol style
ii  libreoffice-writer                    1:5.1.6~rc2-0ubuntu1~xenial4                 amd64        office productivity suite -- word processor
ii  libresid-builder0c2a                  2.1.1-14ubuntu2                              amd64        SID chip emulation class based on resid
ii  librest-0.7-0:amd64                   0.7.93-1                                     amd64        REST service access library
ii  librevenge-0.0-0:amd64                0.0.4-4ubuntu1                               amd64        Base Library for writing document interface filters
And this  from the 3rd.
« Last Edit: September 18, 2018, 11:24:48 am by Mark Greaves (PCNetSpec) »
Re: Libre Calc.
« Reply #13 on: September 18, 2018, 11:16:23 am »
soffice --version
« Last Edit: September 18, 2018, 11:25:54 am by Mark Greaves (PCNetSpec) »
Offline Osmond
  • Full Member
Re: Libre Calc.
« Reply #14 on: September 19, 2018, 08:41:46 am »
LibreOffice 5.1.6.2 10m0(Build:2)
