Author Topic: Libre Calc.  (Read 2570 times)
Re: Libre Calc.
« Reply #15 on: September 19, 2018, 11:26:57 am »
Would you like to try LibreOffice 6 ?
It might fix whatever is broken in your LO 5.
If so, follow the instructions below....
Open a terminal and run the following commands in sequence
sudo apt-get remove --purge libreoffice*
mv ~/.config/libreoffice ~/.config/libreoffice-old
sudo add-apt-repository ppa:libreoffice/ppa
sudo apt-get install libreoffice
Offline Osmond
  • Full Member
Re: Libre Calc.
« Reply #16 on: September 23, 2018, 02:29:47 pm »
Before dealing with Libre Office as you suggest I have been considering going from existing Peppermint 7 to 9 in  which case I could defer Libre business until 9 is in. However, if I simply download 9 does it overwrite 7 or do I end up with both?
Your advice on this would be most welcome.
Osmond
Re: Libre Calc.
Re: Libre Calc.
« Reply #17 on: September 23, 2018, 08:23:15 pm »
The installer should give you the option to REPLACE Peppermint 8, or ALONGSIDE Peppermint 8
Choosing REPLACE will completely wipe the drive, then install Peppermint 9
Choosing ALONGSIDE will shrink the Peppermint 8 partition, and create a new one for Peppermint 9 .. so you choose which to boot into.
On another note, Peppermint 9 already has LibreOffice 6 out of the box.
Offline Osmond
  • Full Member
Re: Libre Calc.
« Reply #18 on: September 26, 2018, 05:00:11 pm »
DIRECT istallation would not come up so I used the recmmended TORRENT. Was not offered a choice of REPLACE or ALONGSIDE. I have ended up with a window which refers to a 128 GB disc and instruction to "Restore disc image". Not sure what's going on here.
Re: Libre Calc.
« Reply #19 on: September 26, 2018, 10:48:22 pm »
Have you burned the ISO image you downloaded to a USB stick ?
If not, what OS are you going to use whilst creating the USB stick .. Peppermint 7 ?
Re: Libre Calc.
Offline Osmond
  • Full Member
Re: Libre Calc.
« Reply #20 on: September 28, 2018, 12:34:27 pm »
Not yet.  Peppermint 7 is all I have.
I notice that DIRECT download works from the Users Guide. Can I abort the TORRENT process and use DIRECT as originally intended?
Re: Libre Calc.
« Reply #21 on: September 28, 2018, 07:25:23 pm »
Of course you can.
here are the direct links.
Peppermint 9 64bit
https://peppermintos.com/iso/Peppermint-9-20180621-amd64.iso
Peppermint 9 32bit
https://peppermintos.com/iso/Peppermint-9-20180621-i386.iso
