Author Topic: Logger failed, read only file system  (Read 5313 times)
Offline ebi612001
« on: September 10, 2018, 06:09:14 pm »
Dear all,
I faced an issue with mu Operating system. Which isthe file from the scanner can not be recorded ar ssd drive. The error is logger..... Failed,read only file system.
Please advise me on how can I solve it.
Thank you so much ?
Re: Logger failed, read only file system
« Reply #1 on: September 11, 2018, 01:36:15 am »
Which Linux distribution and version are you using ?
And are you able to say create a file or folder on your desktop ?
Also, do you get any output if you run this command in a terminal
dmesg | grep -i "error\|warn\|fail"
« Last Edit: September 11, 2018, 01:38:35 am by Mark Greaves (PCNetSpec) »
