Author Topic: Can I Remove Startup Applications  (Read 6312 times)
Offline MattC
« on: October 06, 2018, 08:46:54 pm »
Hi,
I have some 20 or so startup applications and I need to know if I can 'uncheck' any of them to allow faster boot up, etc.
(Incidentally, does 'unchecking' them mean that they will stay in the Startup App Pref screen and just not startup so that I can 'check' them again in the future?  I haven't attempted to do anything yet as I am unsure whether they will 'disappear'!)
Matt
Re: Can I Remove Startup Applications
« Reply #1 on: October 08, 2018, 02:47:48 pm »
Which distro/version
And which "startup applications" ?
Offline MattC
« Reply #2 on: October 08, 2018, 06:49:32 pm »
Hi,  Thanks.
Ubuntu 16.04 LTS
Accessibility Profile Manager Indicator
Backup Monitor
Certificate and Key Storage
Desktop Sharing
Files
GNOME Software
GSettings Data Conversion
Indicator Application
Mount Helper
Network
Onboard
Orca screen reader
Personal File Sharing (Launch Bluetooth ObexPush sharing if enabled)
Personal File Sharing (Launch Personal File Sharing if enabled)
PolicyKit Authentication Agent
PulseAudio Sound System
Secret Storage Service
SSH Key Agent
Update Notifier
User folders update
Zeitgeist Datahub
The laptop is only used for simple stuff, such as web browsing, and all updating is disabled (for reasons I won't bother going into here).
The system takes over two minutes to boot up and into Firefox.  The first minute of that is a blank screen before seeing anything.
Matt
« Reply #3 on: October 10, 2018, 02:35:20 pm »
I seriously doubt if any of those services are slowing the boot sequence .. they're all pretty much loaded after login.
What's the output from
systemd-analyze blame
systemd-analyze critical-chain
Offline MattC
« Reply #4 on: October 14, 2018, 08:23:14 pm »
My apologies for taking so long to respond.
Blame:
         22.176s grub-common.service
         22.091s apport.service
         22.059s ondemand.service
         21.981s speech-dispatcher.service
         16.080s dev-sda1.device
         15.732s ModemManager.service
         15.267s irqbalance.service
         14.876s lightdm.service
          9.701s plymouth-quit-wait.service
          8.991s apparmor.service
          7.427s systemd-logind.service
          7.108s gpu-manager.service
          7.086s rsyslog.service
          7.084s pppd-dns.service
          5.488s NetworkManager.service
          5.229s accounts-daemon.service
          3.767s console-setup.service
          3.701s polkitd.service
          2.465s thermald.service
          2.417s keyboard-setup.service
          2.376s upower.service
          2.153s systemd-tmpfiles-setup-dev.service
          1.989s systemd-udevd.service
Critical-chain:
graphical.target @41.463s
??lightdm.service @26.550s +14.876s
  ??systemd-user-sessions.service @25.941s +423ms
    ??basic.target @19.090s
      ??sockets.target @19.090s
        ??snapd.socket @19.075s +8ms
          ??sysinit.target @18.954s
            ??swap.target @18.953s
              ??dev-disk-by\x2duuid-199a51c1\x2ddb70\x2d4643\x2d85ca\x2dfcf0695e
Does this help?
Matt
« Reply #5 on: October 16, 2018, 01:18:41 am »
Can you run:
dmesg > ~/Desktop/dmesg.txt
you'll then find a file on your desktop called "dmesg.txt" .. can you host that file online somewhere such as
http://www.tinyupload.com/
then provide us with a link so we can download it and look for any errors.
Offline MattC
« Reply #6 on: October 17, 2018, 06:19:10 am »
Hi,
File uploaded to:
http://s000.tinyupload.com/?file_id=72468698785760116934
Matt
PS The 'Notification' for this thread doesn't seem to work.
« Reply #7 on: October 17, 2018, 09:20:19 pm »
I can see no major problems in your dmesg output besides some IPv6 duplicate warnings.
If you don't need it, you could see if disabling IPv6 helps
https://support.purevpn.com/how-to-disable-ipv6-linuxubuntu
If that doesn't help, can you explain:-
How long to boot, and once booted how long to start firefox?
Oh and in answer to your original question .. this for sure can be disabled
GNOME Software
« Last Edit: October 17, 2018, 09:22:02 pm by Mark Greaves (PCNetSpec) »
Offline MattC
« Reply #8 on: October 18, 2018, 08:20:28 am »
Thanks,
The boot up I have just done takes approx. 1:40 - 1:50 to boot to the desktop and then a further 40 - 60 secs to run up Ff and load the first page. (30-40 is Ff loading.)  The uncertainty of the figures is the fact that it's not always certain exactly when the desktop/Ff is ready, as sometimes clicking on an app/link doesn't always work first time.  So it could be as short as around 2:30. (My stopwatch said 2:40.)
At this point no startups have been disabled.
Matt
