Author Topic: Running defragfs  (Read 1077 times)
Offline mikep
  • Sr. Member
  • Me again!
Running defragfs
« on: October 13, 2018, 11:59:37 pm »
Hello Folks,
I've been trying to run defragfs with no success.
Basically, I downloaded it from sourceforge, unpacked it in filemanager, then copied defragfs to usr/bin in a terminal. When I try to run it (using sudo defragfs...) I get "command not found". Ls shows that defragfs does exist in usr/bin, although it's greyed out, so I'm assuming it's not properly unpacked. I tried "make defragfs" in the terminal but got "make: Nothing to be done for 'defragfs'".
Any suggestions welcome. Thanks.
Re: Running defragfs
« Reply #1 on: October 14, 2018, 12:13:15 am »
what's the output from
ls -l /usr/bin/defragfs
Though you do realise Linux filesystems don't really need defragmenting right ?
(caveat - at least they don't normally fragment unless your disk gets full, as the file system always attempts to write files contiguously)
Something else to note - If you have an SSD, because of the way blocks are written/read, you never need to defragment even in Windows (in fact it would be a bad thing to do as it would have zero effect on read times but would shorten the life of the SSD).
« Last Edit: October 14, 2018, 12:20:42 am by Mark Greaves (PCNetSpec) »
Offline mikep
  • Sr. Member
  • Me again!
« Reply #2 on: October 14, 2018, 03:50:48 am »
Here it is Mark,
mike@xubuntu:/usr/bin$ ls -l /usr/bin/defragfs
-rw-r--r-- 1 root root 10091 Oct 13 23:09 /usr/bin/defragfs
I know Linux filesystems don't usually need defragging, but this disk is nearly full and has been partitioned and dual-booted with Windows and chunters away at snail's pace, so I thought it worth a go. And no, it's not an SSD. in fact it's an old IDE drive. I'm about to swap in an SSD and do a nice fresh install of Xubuntu. The defrag is just an experiment really, and what bugs me is not being able to get it to run!
« Reply #3 on: October 16, 2018, 12:29:30 am »
from what I'm reading it defrags files .. not so much the entire drive.
But anyway, if you wanna give it a shot, the reason it's not working is the binary executable hasn't been marked as executable .. you can fix this by running:
sudo chmod +x /usr/bin/defragfs
Offline mikep
  • Sr. Member
  • Me again!
« Reply #4 on: October 17, 2018, 11:05:57 pm »
Thanks Mark,
Defragfs runs now, but I'm getting the following..
mike@xubuntu:/$ defragfs /dev/sda5
defragfs 1.1.1, Released under GPLv3 by John Robson <john.robson@usp.br>, March 2011 (help: $ defragfs / -h)
You must specify a correct directory name!
So I tried this..
mike@xubuntu:/$ cd /dev
mike@xubuntu:/dev$ cd /sda5
bash: cd: /sda5: No such file or directory
fdisk shows the following..
mike@xubuntu:/$ sudo fdisk -l
[sudo] password for mike:
Disk /dev/sda: 232.9 GiB, 250059350016 bytes, 488397168 sectors
Disklabel type: dos
Disk identifier: 0x42414240
Device     Boot     Start       End   Sectors   Size Id Type
/dev/sda1  *           63 122093999 122093937  58.2G  7 HPFS/NTFS/exFAT
/dev/sda2       122095614 488396799 366301186 174.7G  5 Extended
/dev/sda5       122095616 297876865 175781250  83.8G 83 Linux
/dev/sda6       480014336 488396799   8382464     4G 82 Linux swap / Solaris
/dev/sda7       297877504 480006143 182128640  86.9G 83 Linux
Partition table entries are not in disk order.
So fdisk sees /dev/sda5, but cd and defragfs don't. Duh? What am I missing?
« Reply #5 on: October 18, 2018, 12:52:57 am »
Sorry Mike, but I'm not happy providing help with a command I don't know much about that could potentially do damage.
Offline mikep
  • Sr. Member
  • Me again!
« Reply #6 on: October 18, 2018, 03:33:18 am »
OK Mark, that's fair enough. Thank you.
It's academic anyway, as I'll be replacing the disk with an SSD shortly.
Thanks for your input, as always.
M
« Reply #7 on: October 18, 2018, 12:06:37 pm »
You'll be glad you did .. but there's no going back to a spinner once you've tried an SSD :)
