Author Topic: Recover Deleted File  (Read 651 times)
Offline osama.mansoor
« on: October 15, 2018, 01:36:50 pm »
Hi Experts,
Due to some issue one of my dbf file is deleted from Oracle Linux 6.5 which I need to recover I have to google it and found a tool called foremost but when i try to run a command mention on site it does not run and mention the options I don't know why the command is not successfully executed.
Re: Recover Deleted File
« Reply #1 on: October 16, 2018, 12:41:08 am »
No screenshots as attachments please .. if you need to post a screenshot, host it somewhere like
https://imgur.com
then post the URL surroinded by IMG tags.
Whilst I've never used (or even heard of) this application, your screenshot (before I deleted it) showed your command included an "-I" option .. according to the help output there is no "-I" option.
(if that was supposed to denote the INPUT file, it shouldn't have been capitalised)
That said, I'm not sure exactly what the "input file" should be .. so follow this advice at your own risk.
