Author Topic: Signals with trap  (Read 3325 times)
Offline chakib
Signals with trap
« on: October 21, 2018, 02:20:10 pm »
Hello,
I am preparing a small class for students on signals with trap. I understood the use of this principle with the example on signal 2 SIGINT:
trap "echo hello" 2: which displays "hello" each time you press the shortcut ctrl + c.
On the other hand, I have difficulty assimilating the use of the following cases:
1. The effect of signal 3 SIGQUIT.
2. The effect of siganl 9 SIGKILL.
3. The effect of the signal 19 SIGSTOP.
Can you guide me with simple examples please?
Best regard
Re: Signals with trap
« Reply #1 on: October 21, 2018, 10:34:13 pm »
I'm pretty sure SIGKILL and SIGSTOP cannot be trapped (or handled at all).
https://www.shellscript.sh/trap.html
https://stackoverflow.com/questions/35569659/the-signals-sigkill-and-sigstop-cannot-be-caught-blocked-or-orignored-why
Ctrl+\ will send a SIGQUIT signal to the terminal, so maybe
trap "bash -c /usr/bin/gedit" 3
then Ctrl+\ should fire up /usr/bin/gedit
« Last Edit: October 21, 2018, 10:35:45 pm by Mark Greaves (PCNetSpec) »
