Author Topic: Unable to install NGINX in Amazon Linux AMI  (Read 1054 times)
Offline kalaynbl
« on: October 30, 2018, 11:30:56 am »
Hi folks,
I am trying to install NGINX in Amazon Linux AMI
but when i try to run command
sudo yum install nginx
error is below
Loaded plugins: langpacks, priorities, update-motd
Resolving Dependencies
--> Running transaction check
---> Package nginx.x86_64 0:1.14.0-1.el6.ngx will be installed
--> Processing Dependency: libpcre.so.0()(64bit) for package: nginx-1.14.0-1.el6.ngx.x86_64
--> Finished Dependency Resolution
Error: Package: nginx-1.14.0-1.el6.ngx.x86_64 (nginx)
           Requires: libpcre.so.0()(64bit)
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
Any help would be appreciated!
Thank you!
Re: Unable to install NGINX in Amazon Linux AMI
« Reply #1 on: October 30, 2018, 12:01:02 pm »
https://stackoverflow.com/questions/50292023/nginx-is-giving-error-when-i-try-to-install
Your problem might be finding which version of CentOS your version of AMI is based on.
