Author Topic: Can't enable wifi on Novatech laptop after new mint 19 install  (Read 10506 times)
Offline ZapDog5
« on: November 02, 2018, 09:12:20 pm »
Hi folks,
Hoping someone cam help with this. I recently moved from Fedora to Mint 19 and the wifi adapter is hard blocked. I think it's a driver issue but can't resolve it. I can see similar problems have been raised on here and I've tried to follow those solutions but no luck yet.
Any help greatly appreciated!
Offline ZapDog5
Re: Can't enable wifi on Novatech laptop after new mint 19 install
« Reply #1 on: November 02, 2018, 09:12:50 pm »
[email protected]:~$ rfkill list
0: phy0: Wireless LAN
   Soft blocked: no
   Hard blocked: yes
1: hci0: Bluetooth
   Soft blocked: no
   Hard blocked: no
Offline ZapDog5
« Reply #2 on: November 02, 2018, 09:14:03 pm »
System:    Host: DuncanPC Kernel: 4.15.0-38-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu1)
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: Intel product: X300 serial: N/A
           Mobo: INTEL model: HURONRIVER serial: N/A
           UEFI: American Megatrends v: 4.6.5 date: 03/23/2012
CPU:       Dual core Intel Core i5-2467M (-MT-MCP-)
           arch: Sandy Bridge rev.7 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 6384
           clock speeds: max: 2300 MHz 1: 854 MHz 2: 798 MHz 3: 844 MHz
           4: 841 MHz
Graphics:  Card: Intel 2nd Generation Core Integrated Graphics Controller
           bus-ID: 00:02.0
           Display Server: x11 (X.Org 1.19.6 )
           drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: [email protected]
           OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile
           version: 3.3 Mesa 18.0.5 Direct Render: Yes
Audio:     Card Intel 6 Series/C200 Series Family High Def. Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture v: k4.15.0-38-generic
Network:   Card-1: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express)
           driver: ath9k bus-ID: 01:00.0
           IF: wlp1s0 state: down mac: <filter>
           Card-2: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 02:00.0
           IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 128.0GB (19.8% used)
           ID-1: /dev/sda model: M4 size: 128.0GB
Partition: ID-1: / size: 117G used: 24G (22%) fs: ext4 dev: /dev/sda2
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 192 Uptime: 8 min Memory: 837.4/3849.1MB
           Init: systemd runlevel: 5 Gcc sys: 7.3.0
           Client: Shell (bash 4.4.191) inxi: 2.3.56
« Reply #3 on: November 02, 2018, 09:16:10 pm »
Are you sure there isn't a hardware switch on the laptop somewhere .. or a key combo that disables/enables wireless ?
Offline ZapDog5
« Reply #4 on: November 02, 2018, 09:18:04 pm »
Yeah, sure about that.
Fn+F2 should enable it, but doesn't..
« Reply #5 on: November 02, 2018, 09:20:51 pm »
I doubt if this will work with a hard block, but have you tried
sudo rfkill unblock all
Offline ZapDog5
« Reply #6 on: November 02, 2018, 09:22:28 pm »
Yeah, tried that too, but no luck
It worked fine with Fedora previously, so really not sure whats going on
« Reply #7 on: November 02, 2018, 09:25:11 pm »
Has the laptop got a battery ?
If so, try shutting down the laptop
remove the power supply
remove the battery
press the power ON button (to discharge any capacitors on the motherboard)
replace the battery
replace the power supply
power ON
did that sequence make any difference ?
Offline ZapDog5
« Reply #8 on: November 02, 2018, 09:29:23 pm »
The battery isn't accessible without unscrewing the back and taking the whole thing apart.
I saw you'd solved a similar problem with a Novatech laptop by doing a firmware upgrade. I tried that too, but it didn't seem to make a difference.
Thanks for trying to help with this, much appreciated..
« Reply #9 on: November 02, 2018, 09:40:04 pm »
What happens if you run:
sudo modprobe -r ath9k
sudo modprobe ath9k nohwcrypt=1
is it still hard blocked ?
Offline ZapDog5
« Reply #10 on: November 02, 2018, 09:44:19 pm »
I'm afraid so, still hard blocked
« Reply #11 on: November 02, 2018, 09:47:43 pm »
Can you post the output from
lsmod
and then run:
dmesg > ~/Desktop/dmesg.txt
you'll then find a file called dmesg.txt on your desktop .. can you host that somewhere like
http://www.tinyupload.com/
and provide a link to it.
Offline ZapDog5
« Reply #12 on: November 02, 2018, 09:49:25 pm »
lsmod:
Module                  Size  Used by
rfcomm                 77824  16
bnep                   20480  2
intel_rapl             20480  0
ip6t_REJECT            16384  1
x86_pkg_temp_thermal    16384  0
nf_reject_ipv6         16384  1 ip6t_REJECT
intel_powerclamp       16384  0
nf_log_ipv6            16384  5
coretemp               16384  0
xt_hl                  16384  22
kvm_intel             212992  0
ip6t_rt                16384  3
nls_iso8859_1          16384  1
kvm                   598016  1 kvm_intel
irqbypass              16384  1 kvm
crct10dif_pclmul       16384  0
crc32_pclmul           16384  0
ghash_clmulni_intel    16384  0
pcbc                   16384  0
snd_hda_codec_hdmi     49152  1
aesni_intel           188416  0
snd_hda_codec_realtek   106496  1
snd_hda_codec_generic    73728  1 snd_hda_codec_realtek
arc4                   16384  2
aes_x86_64             20480  1 aesni_intel
crypto_simd            16384  1 aesni_intel
glue_helper            16384  1 aesni_intel
cryptd                 24576  3 crypto_simd,ghash_clmulni_intel,aesni_intel
intel_cstate           20480  0
intel_rapl_perf        16384  0
snd_hda_intel          40960  3
snd_hda_codec         126976  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_core           81920  5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_hwdep              20480  1 snd_hda_codec
snd_pcm                98304  4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
ath9k                 151552  0
input_leds             16384  0
ath9k_common           36864  1 ath9k
serio_raw              16384  0
snd_seq_midi           16384  0
ath9k_hw              471040  2 ath9k_common,ath9k
snd_seq_midi_event     16384  1 snd_seq_midi
snd_rawmidi            32768  1 snd_seq_midi
btusb                  45056  0
ath                    28672  3 ath9k_common,ath9k,ath9k_hw
btrtl                  16384  1 btusb
btbcm                  16384  1 btusb
btintel                16384  1 btusb
mac80211              778240  1 ath9k
bluetooth             548864  41 btrtl,btintel,btbcm,bnep,btusb,rfcomm
nf_conntrack_ipv6      20480  8
nf_defrag_ipv6         36864  1 nf_conntrack_ipv6
snd_seq                65536  2 snd_seq_midi,snd_seq_midi_event
ecdh_generic           24576  1 bluetooth
ipt_REJECT             16384  1
nf_reject_ipv4         16384  1 ipt_REJECT
nf_log_ipv4            16384  5
nf_log_common          16384  2 nf_log_ipv4,nf_log_ipv6
xt_LOG                 16384  10
snd_seq_device         16384  3 snd_seq,snd_seq_midi,snd_rawmidi
cfg80211              622592  4 ath9k_common,ath9k,ath,mac80211
snd_timer              32768  2 snd_seq,snd_pcm
snd                    81920  17 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
xt_limit               16384  13
xt_tcpudp              16384  18
lpc_ich                24576  0
shpchp                 36864  0
xt_addrtype            16384  4
soundcore              16384  1 snd
mei_me                 40960  0
mei                    90112  1 mei_me
mac_hid                16384  0
nf_conntrack_ipv4      16384  8
nf_defrag_ipv4         16384  1 nf_conntrack_ipv4
xt_conntrack           16384  16
ip6table_filter        16384  1
ip6_tables             28672  1 ip6table_filter
nf_conntrack_netbios_ns    16384  0
nf_conntrack_broadcast    16384  1 nf_conntrack_netbios_ns
nf_nat_ftp             16384  0
nf_nat                 32768  1 nf_nat_ftp
nf_conntrack_ftp       20480  1 nf_nat_ftp
sch_fq_codel           20480  2
nf_conntrack          131072  8 xt_conntrack,nf_conntrack_ipv6,nf_conntrack_ipv4,nf_nat,nf_nat_ftp,nf_conntrack_netbios_ns,nf_conntrack_broadcast,nf_conntrack_ftp
libcrc32c              16384  2 nf_conntrack,nf_nat
parport_pc             36864  0
ppdev                  20480  0
iptable_filter         16384  1
lp                     20480  0
parport                49152  3 parport_pc,lp,ppdev
ip_tables              28672  1 iptable_filter
x_tables               40960  13 ip6table_filter,xt_conntrack,iptable_filter,xt_LOG,xt_tcpudp,xt_addrtype,ip6t_rt,ip6_tables,ipt_REJECT,ip_tables,xt_limit,xt_hl,ip6t_REJECT
autofs4                40960  2
btrfs                1130496  0
xor                    24576  1 btrfs
zstd_compress         163840  1 btrfs
raid6_pq              114688  1 btrfs
hid_generic            16384  0
usbhid                 49152  0
hid                   118784  2 usbhid,hid_generic
dm_mirror              24576  0
dm_region_hash         20480  1 dm_mirror
dm_log                 20480  2 dm_region_hash,dm_mirror
i915                 1617920  16
i2c_algo_bit           16384  1 i915
drm_kms_helper        172032  1 i915
syscopyarea            16384  1 drm_kms_helper
ahci                   36864  2
sysfillrect            16384  1 drm_kms_helper
sysimgblt              16384  1 drm_kms_helper
libahci                32768  1 ahci
fb_sys_fops            16384  1 drm_kms_helper
r8169                  86016  0
mii                    16384  1 r8169
drm                   401408  5 drm_kms_helper,i915
psmouse               147456  0
video                  45056  1 i915
Offline ZapDog5
« Reply #14 on: November 02, 2018, 09:54:18 pm »
try
sudo modprobe ath9k btcoex_enable=1
still hardblocked ?
