Author Topic: Can't get Dropbox to run at startup  (Read 2946 times)
Re: Can't get Dropbox to run at startup
« Reply #15 on: November 21, 2018, 10:16:01 pm »
Ah right (multiverse)....
Run:
software-properties-gtk
on the first tab make sure "Software restricted by copyright or legal issues (multiverse)" is ticked .. enter your password if prompted, whilst in there it'd also be a good idea to select the second tab (Other Software), and make sure "Canonical Partners" is also ticked .. then "Close" the window.
back in the terminal run:
sudo apt-get install nautilus-dropbox
dropbox start -i
« Last Edit: November 21, 2018, 10:20:03 pm by Mark Greaves (PCNetSpec) »
