Author Topic: (Solved) Help needed to run Windows only programme  (Read 641 times)
Offline donwatson
  • Getting older
« on: November 14, 2018, 09:46:42 am »
Hi ,
I need help to run a Windows programme that will NOT be ported to Linux.
I have tried Wine, Winetricks , Play on Linux, VB etc. but none of them seem to work as I want.
I realise that this problem is not really a Unix problem as such so I can only hope for general advice in this matter.
I am thinking the only way to get this programme to run is by dual booting and using Windows to run this programme. I have a 64 bit January 2014 Windows 7 disc (with Service Pack 1) and hoping this would be OK for the Windows side ??
Any thoughts ??
Don W
« Last Edit: November 17, 2018, 10:01:36 am by donwatson »
Novatech build
External 2TiB HD
Offline Zorba61
Re: Help needed to run Windows only programme
« Reply #1 on: November 14, 2018, 10:34:29 am »
Yeah should run no problem I'm currently dual booting with W8 Only use windows for Photoshop which is easier to do dual booting since I already had windows installed.
« Last Edit: November 15, 2018, 08:29:12 am by Zorba61 »
« Reply #2 on: November 14, 2018, 11:51:17 am »
Why won't it run in Vbox ? .. is it graphics intensive (such as a game) ?
Offline donwatson
  • Getting older
« Reply #3 on: November 17, 2018, 10:00:46 am »
I need control of the USB ports to run this programme as I am trying to control a laser engraver from the programme.
I have a Samsung Notebook with Win 7 that has been resurrected and can run this programme so I can now mark this solved.
Thanks for the help.
Don W
Novatech build
External 2TiB HD
Re: (Solved) Help needed to run Windows only programme
« Reply #4 on: November 17, 2018, 10:34:32 am »
You can have control of the USB ports in Vbox .. how did you install Vbox ?
Offline donwatson
  • Getting older
« Reply #5 on: November 17, 2018, 04:08:22 pm »
Thanks Mark,
I have the Samsung running ok and it does what is needed. I have paid for the key to run the programme on that machine and it will be sent pretty quickly. Thanks for the interest in this, I did have quite a lot of faffing about with various VBox, PlayonLinux, Wine etc. programmes but that is all solved now. I will only be using the Samsung to burn some coasters at the moment but I hope to get it to cut 1/4" plywood soon.
take care
Don W
Novatech build
External 2TiB HD
« Reply #6 on: November 17, 2018, 07:26:13 pm »
Okey dokey Don .. have fun :)
