Author Topic: Problems installing virtualbox [solved]  (Read 800 times)
Offline mikep
  • Sr. Member
  • Me again!
« on: November 16, 2018, 09:00:43 pm »
I'm trying to install virtualbox in a new installation of Xubuntu, by following Mark's advice in a different thread, which I've quoted below (because I don't know how to reference the other thread here).
OK,let's remove any verions of virtualbox that might be installed or partially installed:
sudo apt purge virtualbox*
sudo apt clean
Make sure you have build-essential, linux-headers-generic, and dkms installed:
sudo apt install build-essential linux-headers-generic dkms
add the public key for the oracle virtualbox repo with:
wget -q [url]http://download.virtualbox.org/virtualbox/debian/oracle_vbox.asc[/url] -O- | sudo apt-key add -
Now backup your sources.list:
sudo cp -v /etc/apt/sources.list /etc/apt/sources.list.bak
Now open sources.list for editing:
and add these 2 NEW LINES at the bottom:
###### Oracle VirtualBox repo
deb [url]http://download.virtualbox.org/virtualbox/debian[/url] trusty contrib
SAVE the file and exit gedit.
Back in the terminal update the package cache:
sudo apt update
and install virtualbox-4.3 with
sudo apt install virtualbox-4.3
Check you're a member of the vboxusers group and add yourself if necessary.
One finished installing (and adding yourself to the vboxusers group if necessary) ..REBOOT.
Download the extensions pack for the correct version of virtualbox from here:
https://www.virtualbox.org/wiki/Downloads
here's a direct download llink for the current version (4.3.14):
http://download.virtualbox.org/virtualbox/4.3.14/Oracle_VM_VirtualBox_Extension_Pack-4.3.14-95030.vbox-extpack
and double click it to to install it .. virtualbox will start and offer to install it, click the "Install" button, then scroll to the bottom of the license and click the "I Agree" button, and enter your password when prompted.
Done.
Everthing works until sudo apt install virtualbox-4.3, which gives the following errors
mike@xubuntu:~$ sudo apt install virtualbox-4.3
Reading package lists... Done
Building dependency tree
 virtualbox-4.3 : Depends: libvpx1 (>= 1.0.0) but it is not installable
                  Recommends: libsdl-ttf2.0-0 but it is not going to be installed
mike@xubuntu:~$
I tried the following, but no luck..
mike@xubuntu:~$ sudo apt-get install libvpx1
[sudo] password for mike:
Package libvpx1 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libvpx1' has no installation candidate
mike@xubuntu:~$
Where do I go from here, folks?  This worked in Ubuntu 14.04.
TiA.
« Last Edit: November 26, 2018, 09:09:43 pm by mikep »
Offline SeZo
Re: Problems installing virtualbox
« Reply #1 on: November 16, 2018, 09:09:08 pm »
Maybe it is not working because of the old version?
They are on version 5.2
Have you tried the instructions here:
https://www.virtualbox.org/wiki/Linux_Downloads
Offline mikep
  • Sr. Member
  • Me again!
« Reply #2 on: November 16, 2018, 09:33:58 pm »
Thanks SeZo,
I followed the link, downloaded the Ubuntu 16.04 files, accepted the option to open with the package installer and bingo! I can now open virtualbox 5.2.22.
My next task will be to get it to recognize one or two VMs I created before reinstalling Xubuntu and upgrading to 5.2.22. I'll leave this thread open for the moment since it's the obvious place for any questions I might have on that score.
Offline mikep
  • Sr. Member
  • Me again!
« Reply #3 on: November 26, 2018, 09:09:09 pm »
Ok. I got vb to recognise one of my vms, so I'm marking this solved now.
Thanks again, SeZo.
