Author Topic: Problem removing a source  (Read 719 times)
Offline pooky2483
« on: November 17, 2018, 01:42:38 pm »
I'm trying to remove some sources which are causing problems but I am unable to.
The source I'm trying to remove is 'owncloud'
Ive used
grep ^ /etc/apt/sources.list /etc/apt/sources.list.d/*
To get a list of sources, but when I use Discover to list the sources, 'owncloud' is not there.
I get; (I created a gap of a couple of lines so that what I'm trying to remove is easily seen, near the bottom)
(click to show/hide)
I don't know what to do to get rid of the entries.
Re: Problem removing a source
« Reply #1 on: November 17, 2018, 07:24:32 pm »
What's the output from:
ls /etc/apt/sources.list.d
Because it looks like these are the two for owncloud:-
/etc/apt/sources.list.d/isv:ownCloud:desktop.list:deb [url=http://download.opensuse.org/repositories/isv:/ownCloud:/desktop/Ubuntu_16.04/]http://download.opensuse.org/repositories/isv:/ownCloud:/desktop/Ubuntu_16.04/[/url] /
/etc/apt/sources.list.d/isv:ownCloud:desktop.list.save:deb [url=http://download.opensuse.org/repositories/isv:/ownCloud:/desktop/Ubuntu_16.04/]http://download.opensuse.org/repositories/isv:/ownCloud:/desktop/Ubuntu_16.04/[/url] /
But be aware, simply removing the repo is unlikely to for a version/dependency issue on its own.
BTW, are you trying to set some kind of record for number of PPA's added (and subsequent dependency hell) ?
Offline pooky2483
« Reply #2 on: November 17, 2018, 08:11:15 pm »
alessandro-strada-ubuntu-ppa-xenial.list
alessandro-strada-ubuntu-ppa-xenial.list.save
deadsnakes-ubuntu-ppa-xenial.list
deadsnakes-ubuntu-ppa-xenial.list.save
fengestad-ubuntu-stable-xenial.list
flexiondotorg-ubuntu-youtube-dl-gui-xenial.list
flexiondotorg-ubuntu-youtube-dl-gui-xenial.list.save
getdeb.list
getdeb.list.save
google-chrome.list
google-chrome.list.save
google-earth.list
google-earth.list.save
inkscape_dev-ubuntu-stable-xenial.list
inkscape_dev-ubuntu-stable-xenial.list.save
kubuntu-ppa-ubuntu-backports-xenial.list
kubuntu-ppa-ubuntu-backports-xenial.list.save
nilarimogard-ubuntu-webupd8-xenial.list
nilarimogard-ubuntu-webupd8-xenial.list.save
obsproject-ubuntu-obs-studio-xenial.list
obsproject-ubuntu-obs-studio-xenial.list.save
skype-stable.list
skype-stable.list.save
team-xbmc-ubuntu-ppa-xenial.list
team-xbmc-ubuntu-ppa-xenial.list.save
Re the number of PPA's, no not really, I noticed that too, arent there a lot identical, can we get rid of the unnecessary ones while were at it?
« Reply #3 on: November 17, 2018, 10:05:58 pm »
Deleting these 2 files will get rid of the owncloud repo
/etc/apt/sources.list.d/sv:ownCloud:desktop.list
the running
but rather than delete them you'd probably be better served just DISABLING them in synaptic .. or by commenting out their contents.
BTW, there are no duplicates .. only the repos, and their backups (that end with .save).
Offline pooky2483
« Reply #4 on: November 17, 2018, 10:54:23 pm »
So, to see if they're all needed, what's the command I use to get a list of the programs they update?
« Reply #5 on: November 19, 2018, 10:08:25 pm »
grep ^Package: /var/lib/apt/lists/ppa.launchpad.net_*_Packages
will list all packages installed from PPA's
or you can list the package repos by running
ls /var/lib/apt/lists
then list for example all the packages from say "ppa.launchpad.net_libreoffice_ppa_ubuntu_dists_bionic_main_binary-amd64_Packages" with
grep Package /var/lib/apt/lists/ppa.launchpad.net_libreoffice_ppa_ubuntu_dists_bionic_main_binary-amd64_Packages
source:
https://www.ostechnix.com/list-installed-packages-certain-repository-linux/
Offline pooky2483
« Reply #6 on: November 20, 2018, 12:55:39 am »
I'm not sure how to ask or do it, what I need to do is remove owncloud which is causing problems.
« Reply #7 on: November 20, 2018, 07:02:21 pm »
Impossible to answer without knowing the problem the owncloud repo is giving you
my last but one response tells you how to remove the repo .. but I suspect it's some packages installed via that repo that are your issue .. removing the repo won't uninstall the packages installed from it, that you'll need to do manually.
Offline pooky2483
« Reply #8 on: November 22, 2018, 01:51:35 am »
I get the error when I execute the following...
« Reply #9 on: November 22, 2018, 01:32:33 pm »
Add the key for the owncloud repo:
wget -qO - http://download.owncloud.org/download/repositories/stable/Ubuntu_16.04/Release.key | sudo apt-key add -
enter your password when prompted, then hit enter.
Also add this key because you don't appear to have the normal repo
wget -qO - http://download.opensuse.org/repositories/isv:ownCloud:desktop/Ubuntu_16.04/Release.key | sudo apt-key add -
Now delete the getdeb repo because they've been abandoned:
cd /etc/apt/sources.list.d
sudo rm -v getdeb.list
sudo rm -v getdeb.list.save
now see if you get any errors from:
« Last Edit: November 22, 2018, 01:40:39 pm by Mark Greaves (PCNetSpec) »
