Author Topic: Symbolic linked file  (Read 4447 times)
Offline kwizzymi
« on: November 22, 2018, 12:27:25 pm »
I need to find the source of the symbolic linked file in linux home dir.
I am really struggling to understand but need to submit it really soon
Re: Symbolic linked file
« Reply #1 on: November 22, 2018, 01:18:23 pm »
Okay let's say the symbolic link is in your home folder, and is called "mylink" .. open a terminal and run:
ls -l ~/mylink
the output should show where the symlink points to.
Offline kwizzymi
« Reply #2 on: November 22, 2018, 01:38:59 pm »
Thanks, sorry but im not sure what my home folder is?
my line before I enter code looks like
linux@file-permissions:~$
« Reply #3 on: November 22, 2018, 01:44:21 pm »
You are already in your home folder
represents your home folder in a command path
or you could enter the FULL path which in your case will be
/home/linux
they both mean your home folder.
You could just run:
ls -l ~/
which will give you a long listing of ALL home folder contents .. then look through the output for the symlink.
« Last Edit: November 22, 2018, 01:46:27 pm by Mark Greaves (PCNetSpec) »
Offline kwizzymi
« Reply #4 on: November 22, 2018, 02:09:22 pm »
Thanks, I have the list, but how do I know which one is the symlink?/the source of it?
Edit: I got it actually thanks !!!
« Last Edit: November 22, 2018, 02:27:13 pm by kwizzymi »
« Reply #5 on: November 22, 2018, 03:08:10 pm »
sorted then ?
