Author Topic: [SOLVED] Unable to boot to desktop  (Read 1171 times)
Offline pooky2483
« on: November 27, 2018, 12:14:20 pm »
I have just rebooted my computer* and all seemed well until just after the splash screen, when I got this...
BusyBox v1.22.1 (Ubuntu 1:1.22.0-15ubuntu1) built-in shell (ash)
Enter 'help' for a list of built-in commands.
(initramfs) _ <--- flashing cursor
I have already tried boot repair disk and then rebooted and it booted to the same state as above.
* Just before shut-down of the system to reboot, a couple of warnings popped up telling me that it was unable to write to disk, probably something to do with writing the state of the system to disk!
« Last Edit: November 30, 2018, 01:30:15 pm by pooky2483 »
Offline pooky2483
Re: Unable to boot to desktop
« Reply #1 on: November 27, 2018, 12:18:18 pm »
Just tried booting to a previous kernel and still the same problem...
« Reply #2 on: November 27, 2018, 01:13:35 pm »
Have you got a LiveUSB ?
(really you should always have one of these)
If so, boot to it, and post the output from:
df -h
mount
sudo fdisk -l
Offline pooky2483
« Reply #3 on: November 27, 2018, 02:12:44 pm »
I have, you've probably forgot you helped me install Multiboot (I think it was written by someone French).
Well, I've got the boot repair, gparted and multiple os'es and lots of other stuff.
df -h
Filesystem      Size  Used Avail Use% Mounted on
udev             16G  4.0K   16G   1% /dev
tmpfs           3.2G  1.6M  3.2G   1% /run
/dev/sdi1       117G   38G   80G  33% /isodevice
/dev/loop0      1.1G  1.1G     0 100% /cdrom
/dev/loop1      1.1G  1.1G     0 100% /rofs
/cow             16G  342M   16G   3% /
none            4.0K     0  4.0K   0% /sys/fs/cgroup
tmpfs            16G   12K   16G   1% /tmp
none            5.0M  4.0K  5.0M   1% /run/lock
none             16G   76K   16G   1% /run/shm
none            100M   20K  100M   1% /run/user
mount
/cow on / type overlay (rw)
/dev/sdi1 on /isodevice type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/loop0 on /cdrom type iso9660 (ro,noatime)
/dev/loop1 on /rofs type squashfs (ro,noatime)
none on /sys/fs/cgroup type tmpfs (rw)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev)
none on /sys/fs/pstore type pstore (rw)
systemd on /sys/fs/cgroup/systemd type cgroup (rw,noexec,nosuid,nodev,none,name=systemd)
sudo fdisk -l
Disk /dev/sda: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders, total 234441648 sectors
Disk identifier: 0x0007593a
/dev/sda1   *        2048   234438655   117218304   83  Linux
Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
Disk identifier: 0xd1567197
/dev/sdb1            2048  3907028991  1953513472   83  Linux
Disk /dev/sdc: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x0009b408
/dev/sdc1            2048  3907028991  1953513472   83  Linux
WARNING: GPT (GUID Partition Table) detected on '/dev/sdd'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdd: 8001.6 GB, 8001563221504 bytes
255 heads, 63 sectors/track, 972801 cylinders, total 15628053167 sectors
I/O size (minimum/optimal): 4096 bytes / 33553920 bytes
Disk identifier: 0x9a9c01c5
/dev/sdd1               1  4294967295  2147483647+  ee  GPT
Partition 1 does not start on physical sector boundary.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdg'! The util fdisk doesn't support GPT. Use GNU Parted.
Note: sector size is 4096 (not 512)
Disk /dev/sdg: 3000.6 GB, 3000592982016 bytes
255 heads, 63 sectors/track, 45600 cylinders, total 732566646 sectors
Units = sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk identifier: 0x00000000
/dev/sdg1               1   732566645  2930266580   ee  GPT
WARNING: GPT (GUID Partition Table) detected on '/dev/sdh'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdh: 8001.6 GB, 8001563221504 bytes
/dev/sdh1               1  4294967295  2147483647+  ee  GPT
Disk /dev/sdi: 125.1 GB, 125061562368 bytes
255 heads, 63 sectors/track, 15204 cylinders, total 244260864 sectors
Disk identifier: 0xe921f7a6
/dev/sdi1   *        1953   244260863   122129455+   c  W95 FAT32 (LBA)
« Reply #4 on: November 29, 2018, 09:03:11 pm »
Good god, a million drives....
Which partition and drive contains your OS ?
Offline pooky2483
« Reply #5 on: November 29, 2018, 11:18:39 pm »
The boot device is sda , the 120gb drive
Offline pooky2483
« Reply #6 on: November 29, 2018, 11:22:22 pm »
There's a few not connected, I've got 6 external HD's in total.
2 * 3Tb
2 * 4Tb
2 * 8Tb
2 * 2Tb internal
1 * 120Gb boot drive
Offline pooky2483
« Reply #7 on: November 30, 2018, 01:29:52 pm »
Managed to fix the problem.
I Googled 'ubuntu has booted to busybox' and viewed a few results and found the command to fix the error...
While still in 'Busybox', I typed the command below
fsck /dev/sda1
NOTE: Change the sda1 to where ever you have your OS installed.
Re: [SOLVED] Unable to boot to desktop
« Reply #8 on: November 30, 2018, 09:11:12 pm »
Great stuff, glad a file system check fixed the issue :)
Offline pooky2483
« Reply #9 on: November 30, 2018, 11:15:31 pm »
It looks like it's a common problem.
