Author Topic: Install older version of Thunderbird (resolved)  (Read 892 times)
Offline Tramlink
  • Is the mist clearing
« on: November 30, 2018, 11:32:40 am »
I am using mint 18.3 64bit.
Thunderbird was updated and all my add-ons stopped working.  I need to return to a version where the add-ons were working.
I have downloaded the zip file for Thunderbird 52.9.1 known to work with my add-ons.
How do I install  the downloaded file.
Thanks in advance.
« Last Edit: December 03, 2018, 02:52:25 pm by Tramlink »
Re: Install older version of Thunderbird
« Reply #1 on: November 30, 2018, 09:47:32 pm »
Can you point to where you got the archive, so we can see what's in it.
Offline Tramlink
« Reply #3 on: November 30, 2018, 11:56:41 pm »
Just extract the archive, enter the just extracted "thunderbird" directory, and run the "thunderbird" binary executable by double-clicking on it.
Offline Tramlink
« Reply #4 on: December 02, 2018, 09:40:49 am »
Doing this opens the older version but the newer version is still on my computer.
All the desktop icons open the newer version.
I want to remove the newer version by installing the 52.9.1 version how do I do this?
« Reply #5 on: December 02, 2018, 07:57:21 pm »
Run these commands in sequence:
sudo apt-get remove thunderbird
cd /opt
sudo wget https://ftp.mozilla.org/pub/thunderbird/releases/52.9.1/linux-x86_64/en-GB/thunderbird-52.9.1.tar.bz2
sudo tar xjvf thunderbird-52.9.1.tar.bz2
sudo ln -s /opt/thunderbird/thunderbird /usr/bin/thunderbird
gksudo xed /usr/share/applications/thunderbird-custom.desktop
and when a BLANK file opens, make it read:-
[Desktop Entry]
Encoding=UTF-8
Name=Thunderbird Mail
Comment=Send and receive mail with Thunderbird
GenericName=Mail Client
Keywords=Email;E-mail;Newsgroup;Feed;RSS
Exec=thunderbird %u
Terminal=false
X-MultipleArgs=false
Type=Application
Icon=thunderbird
Categories=Application;Network;Email;
MimeType=x-scheme-handler/mailto;application/x-xpinstall;
StartupNotify=true
Actions=Compose;Contacts
[Desktop Action Compose]
Name=Compose New Message
Exec=thunderbird -compose
OnlyShowIn=Messaging Menu;Unity;
[Desktop Action Contacts]
Name=Contacts
Exec=thunderbird -addressbook
SAVE the file, and exit the text editor.
Now see if Thunderbird Mail in the main menu works, and opens version 52.9.1
To UNDO (and reinstall the more recent version from the repos)
cd /opt
sudo rm -rv thunderbird
sudo rm -v thunderbird-52.9.1.tar.bz2
cd /usr/bin
cd /usr/share/applications
sudo rm -v thunderbird-custom.desktop
sudo apt-get install thunderbird
Done.
« Last Edit: December 02, 2018, 10:48:58 pm by Mark Greaves (PCNetSpec) »
Offline Tramlink
Re: Install older version of Thunderbird (resolved)
« Reply #6 on: December 03, 2018, 02:51:52 pm »
Now working OK......
Thank you for your help.
« Reply #7 on: December 03, 2018, 09:42:39 pm »
You're welcome :)
