Author Topic: Card reader (SOLVED ish)  (Read 2043 times)
Offline Zorba61
  • Full Member
« on: December 01, 2018, 08:27:37 am »
Plugging card reader into Mint 19 gives me a recognition sound albeit slow but then no card is detected or shown to be mounted.I have checked that in the settings it's set to automount but still only sound when plugging and unplugging card reader.The card reader is not listed under devices I'm sure it's probably something simple but I have yet to find an answer that works.
ps
The card I'm trying to read is a XD card.
Thanks.
« Last Edit: December 08, 2018, 10:47:05 am by Zorba61 »
Re: Card reader
« Reply #1 on: December 01, 2018, 02:13:33 pm »
What's the output from:
lsusb
and can you also unplug the card .. wait 10 seconds .. replug the card .. then post the output from:
dmesg | tail -n 40
Offline Zorba61
  • Full Member
Re: Card reader
« Reply #2 on: December 01, 2018, 02:24:02 pm »
lsusb
Bus 001 Device 002: ID 8087:8001 Intel Corp.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 003: ID 8087:07dc Intel Corp.
Bus 002 Device 002: ID 0bda:579c Realtek Semiconductor Corp.
Bus 002 Device 004: ID 14cd:168a Super Top
dmesg | tail -n 40
 793.983618] [UFW BLOCK] IN=wlp9s0 OUT= MAC=f4:06:69:d1:a4:d4:c8:08:e9:79:51:99:08:00 SRC=192.168.1.89 DST=192.168.1.94 LEN=319 TOS=0x00 PREC=0x00 TTL=64 ID=56887 DF PROTO=UDP SPT=34395 DPT=46186 LEN=299
[  853.344087] [UFW BLOCK] IN=wlp9s0 OUT= MAC=01:00:5e:00:00:01:58:98:35:5f:95:64:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=52676 DF PROTO=2
[  912.985147] [UFW BLOCK] IN=wlp9s0 OUT= MAC=f4:06:69:d1:a4:d4:c8:08:e9:79:51:99:08:00 SRC=192.168.1.89 DST=192.168.1.94 LEN=319 TOS=0x00 PREC=0x00 TTL=64 ID=2441 DF PROTO=UDP SPT=33805 DPT=44497 LEN=299
[  912.985630] [UFW BLOCK] IN=wlp9s0 OUT= MAC=f4:06:69:d1:a4:d4:c8:08:e9:79:51:99:08:00 SRC=192.168.1.89 DST=192.168.1.94 LEN=319 TOS=0x00 PREC=0x00 TTL=64 ID=2442 DF PROTO=UDP SPT=33805 DPT=44497 LEN=299
[  913.257497] [UFW BLOCK] IN=wlp9s0 OUT= MAC=f4:06:69:d1:a4:d4:c8:08:e9:79:51:99:08:00 SRC=192.168.1.89 DST=192.168.1.94 LEN=319 TOS=0x00 PREC=0x00 TTL=64 ID=2455 DF PROTO=UDP SPT=33805 DPT=44497 LEN=299
[  913.257827] [UFW BLOCK] IN=wlp9s0 OUT= MAC=f4:06:69:d1:a4:d4:c8:08:e9:79:51:99:08:00 SRC=192.168.1.89 DST=192.168.1.94 LEN=319 TOS=0x00 PREC=0x00 TTL=64 ID=2456 DF PROTO=UDP SPT=33805 DPT=44497 LEN=299
[  913.985387] [UFW BLOCK] IN=wlp9s0 OUT= MAC=f4:06:69:d1:a4:d4:c8:08:e9:79:51:99:08:00 SRC=192.168.1.89 DST=192.168.1.94 LEN=319 TOS=0x00 PREC=0x00 TTL=64 ID=2469 DF PROTO=UDP SPT=47991 DPT=44497 LEN=299
[  962.209650] sd 2:0:0:0: [sdb] 4096000 512-byte logical blocks: (2.10 GB/1.95 GiB)
[  962.540691]  sdb: sdb1
[  967.798136] sd 2:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  967.798144] sd 2:0:0:0: [sdb] tag#0 Sense Key : Aborted Command [current]
[  967.798150] sd 2:0:0:0: [sdb] tag#0 Add. Sense: Incompatible medium installed
[  967.798157] sd 2:0:0:0: [sdb] tag#0 CDB: Read(10) 28 00 00 3e 7f 80 00 00 08 00
[  967.798161] print_req_error: I/O error, dev sdb, sector 4095872
[  972.882259] sd 2:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  972.882265] sd 2:0:0:0: [sdb] tag#0 Sense Key : Aborted Command [current]
[  972.882270] sd 2:0:0:0: [sdb] tag#0 Add. Sense: Incompatible medium installed
[  972.882275] sd 2:0:0:0: [sdb] tag#0 CDB: Read(10) 28 00 00 3e 7f 80 00 00 08 00
[  972.882278] print_req_error: I/O error, dev sdb, sector 4095872
[  972.882287] Buffer I/O error on dev sdb, logical block 511984, async page read
[  977.966227] sd 2:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  977.966231] sd 2:0:0:0: [sdb] tag#0 Sense Key : Aborted Command [current]
[  977.966234] sd 2:0:0:0: [sdb] tag#0 Add. Sense: Incompatible medium installed
[  977.966237] sd 2:0:0:0: [sdb] tag#0 CDB: Read(10) 28 00 00 3e 7f 80 00 00 08 00
[  977.966239] print_req_error: I/O error, dev sdb, sector 4095872
[  978.376185] [UFW BLOCK] IN=wlp9s0 OUT= MAC=01:00:5e:00:00:01:58:98:35:5f:95:64:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=52712 DF PROTO=2
[  979.267387] usb 2-1: reset high-speed USB device number 4 using xhci_hcd
[  980.611297] usb 2-1: reset high-speed USB device number 4 using xhci_hcd
[  983.314608] sd 2:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  983.314613] sd 2:0:0:0: [sdb] tag#0 Sense Key : Aborted Command [current]
[  983.314616] sd 2:0:0:0: [sdb] tag#0 Add. Sense: Incompatible medium installed
[  983.314620] sd 2:0:0:0: [sdb] tag#0 CDB: Read(10) 28 00 00 3e 7f 80 00 00 08 00
[  983.314622] print_req_error: I/O error, dev sdb, sector 4095872
[  983.314629] Buffer I/O error on dev sdb, logical block 511984, async page read
[  988.398778] sd 2:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  988.398786] sd 2:0:0:0: [sdb] tag#0 Sense Key : Aborted Command [current]
[  988.398792] sd 2:0:0:0: [sdb] tag#0 Add. Sense: Incompatible medium installed
[  988.398798] sd 2:0:0:0: [sdb] tag#0 CDB: Read(10) 28 00 00 3e 7d fb 00 00 08 00
[  988.398803] print_req_error: I/O error, dev sdb, sector 4095483
[  989.699559] usb 2-1: reset high-speed USB device number 4 using xhci_hcd
If this helps lspci gave me this
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
Re: Card reader
« Reply #3 on: December 01, 2018, 02:59:53 pm »
I assumed when you said "Plugging card reader into Mint 19" you were referring to a USB card reader ?
Offline Zorba61
  • Full Member
Re: Card reader
« Reply #4 on: December 01, 2018, 03:54:16 pm »
Yes Mark that's what it is a card reader that plugs via usb.
This is it...
« Last Edit: December 01, 2018, 03:59:11 pm by Zorba61 »
Re: Card reader
« Reply #5 on: December 01, 2018, 04:08:12 pm »
Will it read anything else, such as an SD card ?
The reason I ask is because this repeated message:-
Seems to suggest there's an input/output problem with reading the card.
« Last Edit: December 01, 2018, 04:12:38 pm by Mark Greaves (PCNetSpec) »
Offline Zorba61
  • Full Member
Re: Card reader
« Reply #6 on: December 01, 2018, 04:13:12 pm »
Yes reads sd cards
Offline Zorba61
  • Full Member
Re: Card reader
« Reply #7 on: December 01, 2018, 04:31:45 pm »
It worked in Windows 8 and  I've just tried it again in Windows 10 and it works no problem.
« Last Edit: December 01, 2018, 04:34:51 pm by Zorba61 »
Re: Card reader
« Reply #8 on: December 01, 2018, 05:35:59 pm »
You might want to copy off all the files in Windows, then reformat the card in your camera.
Offline Zorba61
  • Full Member
Re: Card reader
« Reply #9 on: December 01, 2018, 07:26:48 pm »
Right card has been formatted by the camera, what next Mark?
Re: Card reader
« Reply #10 on: December 01, 2018, 08:23:01 pm »
See if Linux now recognises the card ?
(or still throws that error in dmesg)
Offline Zorba61
  • Full Member
Re: Card reader
« Reply #11 on: December 02, 2018, 05:12:25 am »
Still nothing and still not listed under device even though it looks like Linux is now seeing it as mass storage  device
dmesg | tail -n 40 ......producers this result which is different to first result,maybe we're getting somewhere?
[  329.705225] usb 2-1.4: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[  329.705228] usb 2-1.4: Product: USB Mass Storage Device
[  329.705230] usb 2-1.4: Manufacturer: USB Device
[  329.705232] usb 2-1.4: SerialNumber: 816820130806
[  329.705544] usb-storage 2-1.4:1.0: USB Mass Storage device detected
[  329.705707] scsi host4: usb-storage 2-1.4:1.0
[  330.737237] scsi 4:0:0:0: Direct-Access     USB Mass  Storage Device  1.00 PQ: 0 ANSI: 0
[  330.737625] sd 4:0:0:0: Attached scsi generic sg2 type 0
[  330.738765] sd 4:0:0:0: [sdb] 4096000 512-byte logical blocks: (2.10 GB/1.95 GiB)
[  330.739351] sd 4:0:0:0: [sdb] Write Protect is off
[  330.739354] sd 4:0:0:0: [sdb] Mode Sense: 03 00 00 00
[  330.739996] sd 4:0:0:0: [sdb] No Caching mode page found
[  330.740002] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[  330.925615]  sdb: sdb1
[  330.928263] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[  332.032380] usb 2-1.4: reset high-speed USB device number 5 using ehci-pci
[  332.124352] usb 2-1.4: device descriptor read/64, error -71
[  332.328370] usb 2-1.4: device descriptor read/64, error -71
[  332.516372] usb 2-1.4: reset high-speed USB device number 5 using ehci-pci
[  332.608356] usb 2-1.4: device descriptor read/64, error -71
[  332.808377] usb 2-1.4: device descriptor read/64, error -71
[  332.996360] usb 2-1.4: reset high-speed USB device number 5 using ehci-pci
[  333.412377] usb 2-1.4: device not accepting address 5, error -71
[  333.492392] usb 2-1.4: reset high-speed USB device number 5 using ehci-pci
[  333.908376] usb 2-1.4: device not accepting address 5, error -71
[  333.908736] usb 2-1.4: USB disconnect, device number 5
[  333.928399] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[  333.928404] sd 4:0:0:0: [sdb] tag#0 CDB: Read(10) 28 00 00 3e 7f 80 00 00 08 00
[  333.928406] print_req_error: I/O error, dev sdb, sector 4095872
[  334.048384] usb 2-1.4: new high-speed USB device number 6 using ehci-pci
[  334.157688] usb 2-1.4: New USB device found, idVendor=14cd, idProduct=168a
[  334.157693] usb 2-1.4: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[  334.157695] usb 2-1.4: Product: USB Mass Storage Device
[  334.157697] usb 2-1.4: Manufacturer: USB Device
[  334.157700] usb 2-1.4: SerialNumber: 816820130806
[  334.157992] usb-storage 2-1.4:1.0: USB Mass Storage device detected
[  334.158121] scsi host4: usb-storage 2-1.4:1.0
[  335.272391] usb 2-1.4: reset high-speed USB device number 6 using ehci-pci
[  335.969216] usb 2-1.4: USB disconnect, device number 6
[  384.332199] [UFW BLOCK] IN=enp6s0 OUT= MAC=01:00:5e:00:00:01:58:98:35:5f:95:64:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=3874 DF PROTO=2
« Last Edit: December 02, 2018, 05:15:20 am by Zorba61 »
Re: Card reader
« Reply #12 on: December 03, 2018, 09:52:06 pm »
Are you using any USB extension cables ?
Have you tried another cable ?
Have you tried another USB port ?
Is there a BIOS setting to limit the USB speed ?
It's still showing "print_req_error: I/O error, dev sdb, sector 4095872" (and other read errors) and apparently disconnecting .. which suggests a problem with the card itself (or possibly the reader/cabling)
Offline Zorba61
  • Full Member
Re: Card reader
« Reply #13 on: December 04, 2018, 06:58:17 am »
Not using extension tried different ports as I've said Mark it works on two computers one using W8 and one using W10 so can't see how it could be cable /reader/ card/usb  problem?
It's no big deal Mark as I can get around the problem with windows but if your happy to keep working at it then I'll happily continue with trying to solve the problem.
« Last Edit: December 04, 2018, 07:08:50 am by Zorba61 »
Offline Zorba61
  • Full Member
Re: Card reader (SOLVED ish)
« Reply #14 on: December 08, 2018, 10:50:02 am »
Update on card reader....It appears that mint doesn't like the xd format of a memory card because when I tried it with a Sd card in the card reader it automatically asked me what I wanted to do with it.Just as well I'm selling the camera that takes xd cards and buying one that uses the more modern sd.
Thanks again Mark for trying.
