Author Topic: Deleting programmes  (Read 1654 times)
Offline Osmond
  • Full Member
Deleting programmes
« on: December 14, 2018, 03:41:25 pm »
Pepermint 9. Using Software Manager I have disabled a superfluous Google Chrome Beta but it still appears in Menu although it can no longer be accessed. How to I get rid of it from Menu?
Osmond
Re: Deleting programmes
« Reply #1 on: December 14, 2018, 07:52:08 pm »
What's the output from:
ls /usr/share/applications | grep chrome
ls ~/.local/share/applications | grep chrome
Offline Osmond
  • Full Member
« Reply #2 on: December 15, 2018, 10:10:42 am »
No response from the first code.
Second code:chrome-aohghmighlieiainnegkcijnfilokake-Default.desktop
chrome-apdfllckaahabafndbhieahigkjlhalf-Default.desktop
chrome-blpcfgokakmgnkcojhhkbfbldkacnbeo-Default.desktop
chrome-pjkljhegncpnkpknbcohdijeoejaedia-Default.desktop
google-chrome-beta.desktop
googlechromebeta.desktop
google-chrome.desktop
googlechrome.desktop
« Reply #3 on: December 15, 2018, 01:43:03 pm »
Run:
rm -v ~/.local/share/applications/google-chrome-beta.desktop
rm -v ~/.local/share/applications/googlechromebeta.desktop
is it gone from the menu now ?
Offline Osmond
  • Full Member
« Reply #4 on: December 15, 2018, 04:00:14 pm »
First:-   removed '/home/geoffrey/.local/share/applications/google-chrome-beta.desktop'
Second:-  removed '/home/geoffrey/.local/share/applications/googlechromebeta.desktop
Yes. Thank you. Is there no other way of doing this sort of thing other than getting on the Forum?
« Reply #5 on: December 15, 2018, 07:10:32 pm »
Yes, the menu editor.
Right-click the "Menu" button, and select "Edit Applications" .. find the application on the left, then on the right select "Hide in the menu".
« Last Edit: December 26, 2018, 07:52:48 pm by Mark Greaves (PCNetSpec) »
Offline Osmond
  • Full Member
« Reply #6 on: December 26, 2018, 10:21:29 am »
Thanks for your help.
Osmond
