Author Topic: Boot Repair Disks  (Read 1543 times)
Offline gordon99
Boot Repair Disks
« on: February 11, 2019, 10:48:49 pm »
I am intending to add Linux Mint to my Laptop, dual booting with Windows 10 (64 Bit) which is already installed in UEFI Boot mode.  I think the general advice is to create a Boot Repair disk before anything else.  I already have a recently made Windows 10 System Recovery USB drive and wondered if it will suffice in place of a Boot Repair Disk or should I have both.  i would appreciate some guidance on this.
Offline wishbone
Re: Boot Repair Disks
« Reply #1 on: February 12, 2019, 07:39:29 pm »
You could have a look at this, it works pretty good and saved my bacon a couple of times.
https://sourceforge.net/p/boot-repair-cd/home/Home/
« Reply #2 on: February 12, 2019, 11:19:33 pm »
I'm not sure why you'd need a boot repair disk ?
The Mint LiveUSB/LiveDVD media you'll be using can be used to fix the GRUB bootloader if necessary (though it's unlikely you're going to need to.
Offline Zorba61
« Reply #3 on: March 19, 2019, 01:52:46 pm »
If the OP is worried about not being able to boot back into Windows if Mint is removed then this will fix it.In windows open command and run  BootRec.exe/FixMbr
