Author Topic: Installed application is not showing in the ALL APPLICATIONS LIST  (Read 3467 times)
Offline Sabinus
Hi all,
I am now in my second week as a Linux mint (Cinammon) user. However, I installed an Application called Youtube-dl from the software manager but I cannot see the application in the ALL APPLICATIONS list on my laptop. I am running Linux MINT 19.1 CINAMMON and my laptop is HP pavillion DV7. Since installing it, I have restarted the laptop but still cannot see it. This is making me wonder if I am doing something wrong. Could someone please point out where the app is hiding.
Thanks for your attention
Re: Installed application is not showing in the ALL APPLICATIONS LIST
« Reply #1 on: February 15, 2019, 03:13:30 pm »
youtube-dl is a command line application only, not a graphical (GUI) application .. so won't show up in the menu.
But...
There is a GUI front end for youtube-dl called youtube-dlg
To install it in Mint 19, open a terminal and run these commands in sequence
cd ~
wget https://launchpad.net/~nilarimogard/+archive/ubuntu/webupd8/+files/youtube-dlg_0.4-1~webupd8~bionic9_all.deb
sudo apt-get install ~/youtube-dlg_0.4-1~webupd8~bionic9_all.deb
enter your password when prompted .. and (if prompted) accept any other changes it needs to make by entering Y
Once installed you'll find it in the menu at:-
Menu > Internet > Youtube DL GUI
« Last Edit: February 15, 2019, 03:17:05 pm by Mark Greaves (PCNetSpec) »
Offline Sabinus
« Reply #2 on: February 16, 2019, 01:47:31 am »
But...
cd ~
Wow, thanks a million. I have been able to install it by copying and following your direction/s. I am getting more and more into this OS.
Once again, thaaaaaank YOU.
« Reply #3 on: February 16, 2019, 10:26:50 am »
You're most welcome :)
Offline Sabinus
« Reply #4 on: February 23, 2020, 04:37:36 pm »
But...
cd ~
Hi Mark, is there a reason to prevent this application from working? I have had my linux mint 19.1 upgraded to 19.3. Sice upgrading, any time I try to download anything with the youtube-dlg, it gives error message and does not download anything. Is there any work around?
« Reply #5 on: February 23, 2020, 05:20:01 pm »
I'm sorry to tell you that Mark passed away a short while ago, but perhaps another mentor will be able to help you.
Offline wishbone
« Reply #6 on: February 23, 2020, 07:20:54 pm »
It should be in Synaptic Package Manager like this:
https://imgur.com/PLTKDw1
You could also try this:
https://www.4kdownload.com/
Offline karanprakash30
« Reply #7 on: October 27, 2020, 08:33:15 am »
Or else you can go for YouTube2Video:
https://www.youtube2video.com/en/
